Old 11-07-2022, 01:34 PM
Chevelle 71 Chevelle 71 is offline
Default New Guy
Hello all,
As my name states you can probably tell I have a 69 Mustang
Joining forum to get ideas on what to do next. Been lurking for a few months and also on the pro touring forum.
This is Veronica (I don’t usually name my cars but a friend named her and I thought it fit so it stuck)
No grief about wheels! On there when I bought them and will either be doing BC forged or Weld Ventura’s this winter.
Ridetech front shockwaves with there front Upper and lower control arms, strong arms and shock waves and Hotchkis control arms and sway bar rear.
Reason for the mix and match was Hotchkis control arms already on rear so just added the sway bar.
Brakes are Willwood Aero6’s and superlites
Motors a 489 and was thinking LS but she was built so well and sounds amazing. Scat internals
Hopefully EFI’d and aluminum heads this winter. Will update all fittings to black.
She’s a basic bolt on build but I wanted a driver I could drive the sh!t out of so she works.
Anyways hello!
The Following 3 Users Say Thank You to Chevelle 71 For This Useful Post:
camcojb (11-07-2022), Goosesdad (11-30-2022), Roscoe03 (11-24-2022)
Old 11-07-2022, 02:49 PM
Great car!! Welcome to the site.
Chevelle 71 (11-07-2022)
Old 11-08-2022, 11:00 AM
fleetus macmullitz's Avatar
Welcome!
Great starting point…and looking forward to seeing more of it.
The Following User Says Thank You to fleetus macmullitz For This Useful Post:
Chevelle 71 (11-08-2022)
Old 11-09-2022, 07:23 AM
Pro Touring Store Pro Touring Store is offline
Nice ride already!
Happy to help you out on any parts needs as you progress!
-Dale
Dale Schwartz
www.ProTouringStore.com
The Following 2 Users Say Thank You to Pro Touring Store For This Useful Post:
Chevelle 71 (11-12-2022), simbad's68 (11-10-2022)
Old 11-10-2022, 07:17 PM
Welcome to the site. Nothing wrong with Torque Thrust wheels. They're a good looking wheel which is why they're everywhere.
The car looks great. If the BBC is running well and making the power you want, adding EFI is the way I would go.
Good luck with it. Keep us posted!
Old 11-24-2022, 07:14 PM
Roscoe03 Roscoe03 is offline
Sweet ride. Looking forward to see what you have planned for it.
Old 11-27-2022, 01:18 PM
AMSOILGUY's Avatar
AMSOILGUY AMSOILGUY is offline
Great car! I just did a EFI upgrade on BBC and it was a big improvement over the carb I had. I hear some have carbs are less problems then mine was.
[email protected]
www.jacobehlers.com
Old 11-29-2022, 06:14 AM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Default Holley Terminator EFI
Andrew (Dr EFI) helped with the Holley Terminator EFI on my 440ci Pontiac and it completely changed the car! So I'm a firm believer that if the BBC was built well and is running well already you should keep it and just enjoy the modern convenience, efficiency and power gains from an EFI conversion!
1} Rick's tanks should make a RestoMod tank for your Chevelle...
2} Get with Carl at VaporWorx for the GM fuel module to drop into that tank and all of your fuel needs are covered.
3} Get with Andrew (Dr. EFI) to have him tune the EFI on your BBC!
The aluminum heads would be a great power adder but can always be added later and Andrew could easily return the new engine combo for you virtually. Of course if you have the funds I'd add some good flowing aluminum heads (310-325cfm) and ask Andrew for a cam recommendation (248/260) to work well with the EFI and just send it! You'll be glad you did!
Cool car with lots of tasteful mods already... I'd focus on the above and then your wheels of choice if it were me.
AND please move that remote oil filter from under the vehicle before it gets hit or ripped off and you kill that BBC!
Ty Ingle, USAF Retired
FREEDOMBIRD
The Following User Says Thank You to OLDFLM For This Useful Post:
Chevelle 71 (09-21-2023)
Old 03-13-2023, 05:53 AM
jarhead's Avatar
jarhead jarhead is offline
Welcome aboard!
I bought a 72 Chevelle 402 in 74 after graduating high school. Loved that car
joe
Semper Fi
My 68 Torino
Old 09-21-2023, 03:02 AM
Wheels on and terminator MPFI ordered. Figuring out heads and rotating assembly next.
The Following 4 Users Say Thank You to Chevelle 71 For This Useful Post:
camcojb (09-21-2023), Goosesdad (09-27-2023), Roscoe03 (09-29-2023), WSSix (09-22-2023)
