Old 01-28-2023, 08:36 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Looking good!!
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 02-04-2023, 03:12 PM
68454RS's Avatar
68454RS 68454RS is offline
Got the body off today, swapped the carb and got it running better but not good. Need to throw a carb kit at it and try again.
Now that the body is off I can do all the wiring, install the Vintage Air A/C kit, re-do the fuel and brake lines. I need to drill out all the rivets to remove the floor panels so I can add thermal barrier and insulation.
Also got my Ridetech rear links for the 8.8 housing
20230204_160804 by F G, on Flickr
20230204_160826 by F G, on Flickr
20230204_160850 by F G, on Flickr
20230204_165857 by F G, on Flickr
The Following 6 Users Say Thank You to 68454RS For This Useful Post:
214Chevy (02-07-2023), andrewb70 (02-10-2023), camcojb (02-04-2023), Goosesdad (02-05-2023), syborg tt (06-19-2023), WSSix (02-04-2023)
  #13
Old 02-22-2023, 06:51 AM
68454RS's Avatar
Small updates, re-engineered the trans mount, got rid of whatever mount was on there, went with a factory style GM mount, flipped the FFR bracket, re-drilled it and now have yoke clearance, Clarence.
Got the headers & pipes removed and boxed up, ready to send off to Jet-Hot Coatings to have everything thermal coated to hopefully help reduce heat output. They say it's a 65% reduction so.....
Pulled the valve body out of the 700R4 trans and it's ready to head to TCI to have the constant pressure modification done.
And then did the Second Skin Mega Block thermal insulation in the floor. The stuff isn't cheap so i'm expecting exceptional results. It's only 1/2" thick so I doubled up on it so it's 1" thick. Waiting on some 3M 5200 to seal and finalize it.
The Following 2 Users Say Thank You to 68454RS For This Useful Post:
Goosesdad (02-23-2023), syborg tt (02-25-2023)
  #14
Old 02-22-2023, 06:57 AM
68454RS's Avatar
my home made vapor system, fuel tank check valve to a Mazda vapor canister to an old fuel filter that has a sintered bronze filter inside. It's crude by y'all's standards but it seems to work.
20230212_161325 by F G, on Flickr
20230212_161341 by F G, on Flickr
camcojb (02-23-2023), syborg tt (02-25-2023)
  #15
Old 02-22-2023, 09:18 AM
andrewb70's Avatar
Nice work, Frank!
Andrew
Instagram @dr__efi
I deliver what EFI promises.
My YouTube Channel
The Following User Says Thank You to andrewb70 For This Useful Post:
68454RS (02-22-2023)
  #16
Old 02-22-2023, 10:39 AM
ScotI ScotI is online now
Would you have any additional images to share of the various parts & pieces?
We were having a similar discussion on another forum (regarding fuel tank venting & vapor collection/reduction).
I'll take an effective low-buck (relatively speaking) option if it's functional. I build drivers not 'showers'.
Old 02-22-2023, 11:00 AM
68454RS's Avatar
https://www.rockauto.com/en/moreinfo...971360&jsn=715
ScotI (02-22-2023), syborg tt (02-25-2023)
  #18
Old 02-22-2023, 06:46 PM
F'in mine's Avatar
If I'm not mistaken I thought the end of the vent had to be placed higher than the tank.
https://www.tanksinc.com/index.cfm/p...cat/cat160.htm
1969 Camaro SSRS
Simon
Old 02-23-2023, 06:44 AM
68454RS's Avatar
Yes, It should be, but that's a s high as mine can go without being outside the body
The Following User Says Thank You to 68454RS For This Useful Post:
  #20
Old 02-23-2023, 02:13 PM
Goosesdad's Avatar
To Simon's point, I think that vent line is going to fill with fuel, thus blocking the vent. What about if we come up with a cool body mod to hide it? It's 'glass right there, correct?
Have a great day!
John
My Build Thread:
