Old 02-09-2023, 08:13 PM
syborg tt's Avatar
Default Well that was a bust
So, I tried to remove the pins however the heat shrink is so close to the terminal that it is
impossible to pull on gently. The other issue is the black retaining clip is in the way so I quit.
Moving to plan B. I going to have a gentleman out from Florida build me a new Coil harness that
is wired correctly and I am sending these back to Summit Racing since the guys at Wiring Specialties
were not interested in Helping me.
Here is the picture before I move the black clip back and now imagine how tight the space is.
Much better picture for reference
marty-mj
fleetus macmullitz (02-09-2023)
  #2032
Old 02-10-2023, 08:39 AM
andrewb70's Avatar
Just cut the heat shrink off, then when all the terminals are out of the connector, you can add a new piece of heat shrink before pushing the terminals back into the connector.
Andrew
Instagram @dr__efi
I deliver what EFI promises.
My YouTube Channel
The Following 2 Users Say Thank You to andrewb70 For This Useful Post:
Hotwire (02-13-2023), syborg tt (02-21-2023)
  #2033
Old 02-23-2023, 02:48 PM
syborg tt's Avatar
Default Just a Quick Update (( 02-05-23 ))
At some point have to install this 150amp breaker on the frame.
Not really needed but Billet Stuff is really nice
So, I saw the add for Screaming Chicken on the site and well I am ordering more parts from them. These will be on the next order.
In a couple days you will see some of the stuff I have already received from them and I also found more Chunky Bars.
marty-mj
The Following 5 Users Say Thank You to syborg tt For This Useful Post:
camcojb (02-23-2023), colorado80439 (02-23-2023), fleetus macmullitz (02-23-2023), Goosesdad (02-23-2023), Roscoe03 (02-24-2023)
  #2034
Old 02-23-2023, 06:19 PM
syborg tt's Avatar
Default Power Steering Fluid and Another Fuel Leak (( 02-12-23 ))
I had filled the Power Steering Reservoir prior to the first start and I forgot to check the fluid levels after we started
the car. A couple days later I decided to check the fluid levels and guess what it was empty.
Andrew AKA Dr. EFI Noticed the O2 reading were all over the place so I ordered a new new Holley O2 Sensor from Summit.
Apparently I missed the pft tape on this fitting. So now I am going back and correcting this major mistake as
I don't want the car to catch on fire. I will need to empty the fuel line again and yes I wish would have fixed both fuel
issue's at the same time.
I also disconnected the Fuel Pump power so the fuel wouldn't drip on the weatherpack connector.
Once the fuel stopped leaking I reconnected the line.
I used some simple green to dilute the fuel and poured the mixture into a small bottle that I will drop off at my
buddy's shop for him to dispose of properly.
Look Ma...No Tape !!
Now I get to remove one of my many notes.
marty-mj
  #2035
Old 02-23-2023, 07:27 PM
syborg tt's Avatar
Default A Long Long Time Ago I was supposed to start this project ((02-12-23 ))
I actually can't tell you how long ago I bought this ford Fan set up. But what I can tell you is Andrew (( Dr EFI )) suggested I
buy this fan set for the PWM fan controller.
Remember, Chemo really killed my memory so labeling all of the wires really helps me.
Plus it looks really cool.
Clear heat shrink over the top prevent the printing from coming off.
I started searching the engine bay to see where I could mount it and I quickly decided it needed to go on the front of the core support.
As you can see it's not a small module.
I removed the Overflow tank and marked a hole so I could drill & mount the module.
Module is prepped to mounted.
A quick trip to Home Depot for Stainless Steel Hardware. I bought Phillips head and Hex head bolts.
I opted to use the Hex head bolts as it would be very difficult to get Phillips screwdriver on the bolt due to it's location.
Looking down you can see it would be much easier to get a box end wrench on the bolt. Hopefully I will never have
to remove it but with proper planning it will be much easier to work on.
Now that the module is mounted I need to route the wires cleanly and safely.
So there is this nice factory hole in the core support.
The wire would route into the engine bay, then down and over towards the fan.
Getting power to the fan is the next project.
I am planning on securing the harness in the middle.
I was late so I called it a night and like always I a sure this wire routing will change tomorrow.
marty-mj
The Following 4 Users Say Thank You to syborg tt For This Useful Post:
camcojb (02-23-2023), colorado80439 (02-23-2023), Goosesdad (02-23-2023), Roscoe03 (02-24-2023)
  #2036
Old 02-23-2023, 07:35 PM
syborg tt's Avatar
Default Holley Cylinder Head Ground Wire (( 02-13-23 ))
I noticed the Holley Cylinder Head ground wire was really close to being pinched by the line clamp. So I removed it
from the back of the Cylinder Head and ran the wire further down the loom.
It is now at least one inch from the line clamp
marty-mj
The Following 3 Users Say Thank You to syborg tt For This Useful Post:
camcojb (02-23-2023), fleetus macmullitz (02-23-2023), Goosesdad (02-23-2023)
  #2037
Old 02-23-2023, 07:57 PM
syborg tt's Avatar
Default Working on the PWM wire routing (( 02-15-23 ))
This is not like me to leave my tools out.
Apparently, I was very tired and just didn't have it in me to clean up.
Today, I will be finishing up the connection to the fan and the battery.
I started running the wires to the fan like I had originally planned but that quickly changed.
I will need to make the hole a little bigger so I can put in a grommet. Which will allow me to run the wires safely through this hole.
I used Vaseline on the drill bit to capture the metal shavings.
The hole is bigger and the grommet fits perfectly.
I taped the three wires together to make it easier to route them.
Mocking up the wire routing to the battery.
Calling it a night and of course I created a list of things that I need to do.
marty-mj
camcojb (02-23-2023), fleetus macmullitz (02-23-2023), Goosesdad (02-23-2023), Roscoe03 (02-24-2023)
  #2038
Old 02-23-2023, 08:02 PM
syborg tt's Avatar
Default Painless Performance LS1/LS6 Coil Harness (( 02-16-23 ))
I ordered the Painless Performance LS1/LS6 Coil Harness from Summit Racing and I plan to send the Wiring Specialties Harness to Andrew to see if he can rework it.
I mocked it up and it works and I only have to rework the last two Cylnders.
You can see there is about 3" of excess wire.
marty-mj
  #2039
Old 02-24-2023, 09:11 AM
ur-n-8 ur-n-8 is offline
I'm sure you have already verified this, but does the sway bay make contact with the tow bar when the car is on jackstands?
The Following User Says Thank You to ur-n-8 For This Useful Post:
syborg tt (02-25-2023)
  #2040
Old 02-25-2023, 07:44 AM
syborg tt's Avatar
It actually sits in front of the sway bar so there are no issue's
I will get better pictures (( Side Shots )) today and add it to this post.
marty-mj
