Old 02-03-2023, 06:41 PM
Blown353 Blown353 is offline
I was planning on using twin ZL1 pumps on my car much like Stielow did on one of his recent builds, but depending on your system backpressure a single Pierburg CWA100-3 or CWA150 might move just as much water as the twin ZL1 pumps while also taking up less space, needing less plumbing, and having the ability to control their speed via PWM input... and it would be cheaper too.
Based on tecomotive's page with the current exchange rate a CWA100-3 with connector kit can be had for about $277 plus shipping, and a CWA150 with connector kit is about $226... that's tempting, I might have to sell my 2x ZL1 pumps and get one of those.
Nice thing about the ZL1 pumps is they're available everywhere though-- dealers, Summit, Jegs, SDPC, etc. The Pierburg pumps do have VAG part numbers though for OEM VW/Audi applications, so they should also be readily available.
1969 Chevelle
The Following 5 Users Say Thank You to Blown353 For This Useful Post:
andrewb70 (02-04-2023), camcojb (02-04-2023), Goosesdad (02-05-2023), kwhizz (02-04-2023), waynieZ (02-08-2023)
  #452
Old 02-04-2023, 10:38 AM
Sounds like the way to go pump-wise, thanks guys.
The Following 2 Users Say Thank You to camcojb For This Useful Post:
andrewb70 (02-08-2023), kwhizz (02-04-2023)
  #453
Old 03-09-2023, 06:26 PM
Sold our house in California and bought a house in Medford OR to be by family. Dropped the car off Dave May of Genesis Fab in Galt Ca. to raise the driveshaft tunnel before the painter gets the car. Did a great job, super reasonable, and whipped it out on a day!
The Following 11 Users Say Thank You to camcojb For This Useful Post:
andrewb70 (03-09-2023), Che70velle (03-09-2023), fleetus macmullitz (03-10-2023), Goosesdad (03-09-2023), jarhead (04-26-2023), Ketzer (03-10-2023), kwhizz (03-10-2023), Roscoe03 (03-14-2023), syborg tt (03-16-2023), waynieZ (03-10-2023), WSSix (03-09-2023)
  #454
Old 03-09-2023, 08:18 PM
Good luck on the move, Jody.
The Following 3 Users Say Thank You to WSSix For This Useful Post:
camcojb (03-10-2023), kwhizz (03-10-2023), waynieZ (03-11-2023)
  #455
Old 03-10-2023, 08:40 AM
Smart move all the way around!!
The Following 2 Users Say Thank You to Vegas69 For This Useful Post:
camcojb (03-10-2023), kwhizz (03-11-2023)
  #456
Old 03-10-2023, 10:43 PM
Steve68 Steve68 is offline
yeah! What he said! beautiful state, but you have to know when to go,
I went almost 7 times a year for 20 years, still didn't see everything I wanted to
The Following User Says Thank You to Steve68 For This Useful Post:
camcojb (03-11-2023)
  #457
Old 04-28-2023, 07:12 PM
HEEP's Avatar
HEEP HEEP is offline
Fitted the firewall smoothing plate from ABC Performance, fit great. Mounted up the Restomod Air a/c unit inside the car, and the bulkhead on the firewall. Special thanks to Rick at Vintage Air for building me a custom compressor line manifold to clear the turbo and wastegate.
My Inland Empire driveshaft showed up, and I was able to find an SS dash through National Parts Depot that actually uses chrome around the bezels and lettering instead of silver paint. Looks a lot better than other reproduction dashes. Started fitting the Dakota Digital gauges to the new dash.
Is your plan to cut out the original metal of the firewall and weld in the new metal or overlay this?
Thanks, Bill
Bill
My Build Thread;
https://lateral-g.net/forums/showthread.php4?t=40557
Old 04-28-2023, 07:32 PM
I have already mounted the A/C unit inside (used weld studs) so the firewall cover was welded over the top. I did trim the lip around the original A/C section of the firewall so the cover plate laid flat over the top. I actually changed to a different firewall cover that has some bead rolling in it, fit well and looks even better IMO. I don't have any pics but it's this one.
https://modshopinc.net/store/index.p...7krp6jchtjqui1
The Following 3 Users Say Thank You to camcojb For This Useful Post:
Goosesdad (05-01-2023), Roscoe03 (05-01-2023), waynieZ (07-04-2023)
  #459
Old 04-29-2023, 07:48 AM
andrewb70's Avatar
I am using a CWA150 pump from Tecomotive. Tobias is very responsive via email in case there are any questions and the pump arrived in less than a week.
Andrew
Instagram @dr__efi
I deliver what EFI promises.
My YouTube Channel
Old 05-09-2023, 06:11 AM
zz430droptop67rs's Avatar
zz430droptop67rs zz430droptop67rs is offline
Jody, I saw this and thought about yours.
The Following 3 Users Say Thank You to zz430droptop67rs For This Useful Post:
214Chevy (05-10-2023), camcojb (05-09-2023), waynieZ (07-04-2023)
Tags
70 chevelle, aeromotive, american powertrain, amsoil, baer brakes, borgeson, clayton machine, currie, dakota digital, eddie motorsports, forgeline, holley performance, hydratech, ididit, lateral-g, lokar, magnaflow, mcleod racing, mighty mouse solutions, modo innovations, morris classic concepts, painless performance, protouring, restomodair, roadster shop, rock valley antique auto parts, ron davis, texas speed, thermotec, tmi products, vintage air
