Old 05-06-2023, 11:36 AM
Empty1 Empty1 is offline
Default Electric Fuel Pump install for carbureted engine
I am reaching out to the collective advantage and wealth of experience and knowledge for guidance. I am in the process of installing a new Tanks, inc fuel system in my 74 Firebird that has an in tank electric fuel pump, routed up through an in-line filter, to a fuel regulator that will reduce the flow for a carbureted engine and will be mounted in the engine bay.
That much i pretty much understand and the rational was that i needed to replace the original pump anyway. The electric fuel pump should provide more consistent fuel to the engine and if/when i ever wanted to replace my Pontiac 400 with an LS engine, I’d be that much closer.
The questions i am wrestling with and why i am reaching out is:
1. Do i need to install a return line from the regulator back to the tank?
2. If so, how is this routed? Right next to the outbound fuel line? What kind of hose clamps do you recommend?
3. Is it necessary, or does it make sense to cut an access door into the trunk floor?
I may end up with more questions, but if i knew the answer to the return line dilemma i think i could get close.
Sent from my iPad using Tapatalk
Old 05-06-2023, 06:29 PM
camcojb camcojb is online now
What fuel pump are you running?
Old 05-07-2023, 10:13 AM
From the product description: “Includes our GPA series fuel pumps 255lph with Walbro pump”
Old 05-07-2023, 11:13 AM
All the regulators I've used with an EFI style fuel pump and a regulator to get it down the 6-7 psi for a carb require a return line to the tank. Easiest to run it back next to the feed line from the tank.
Old 05-08-2023, 04:43 PM
Thank you
The Following User Says Thank You to Empty1 For This Useful Post:
camcojb (05-08-2023)
Old 05-28-2023, 09:33 AM
572Camaro's Avatar
I didn’t cut an access in my trunk floor but wish I had.
Hose clamps? None, I run Swagelok tubing and fittings. Very nice stuff
The Following User Says Thank You to 572Camaro For This Useful Post:
camcojb (05-28-2023)
Old 05-31-2023, 12:18 AM
68LS1's Avatar
68LS1 68LS1 is offline
Default Holley 12-129
You maybe too far down a path, but Holley offer this in tank pump with regulator for 6psi. If you want to move to EFI, you swap out internal regulator
https://www.holley.com/products/fuel...s/parts/12-129
Roger
68 RS Camaro Convertible LS1 6 speed
72 C10 SWB Stepside, old skool 350 4L60e
71 K5 Blazer 350sbc T350
The Following User Says Thank You to 68LS1 For This Useful Post:
camcojb (05-31-2023)
Old 06-08-2023, 06:26 PM
Goosesdad's Avatar
Goosesdad Goosesdad is online now
I'm sure this is way late and you are already up and running but I just swapped my Holley Sniper to a carb. 351W in a 39' truck. Used the same EFI pump, changed the regulator and filter. All good.
Have a great day!
John
My Build Thread:
The Following User Says Thank You to Goosesdad For This Useful Post:
camcojb (06-08-2023)
