Old 05-19-2023, 11:14 PM
camcojb camcojb is online now
colorado80439 (05-21-2023)
  #112
Old 05-21-2023, 06:42 AM
colorado80439 colorado80439 is offline
Default Engine
LS7 dry sump came from a donor C6 Z06 with 4K miles, a service manager at a Chevy dealer acquired the engine for a build that wasn't happening, so I purchased it from him
The Following 4 Users Say Thank You to colorado80439 For This Useful Post:
camcojb (05-21-2023), fleetus macmullitz (06-26-2023), Goosesdad (05-22-2023), syborg tt (06-19-2023)
  #113
Old 05-22-2023, 08:03 PM
I liked what Katech has to offer for the LS7, plenty of R & D verifing their cam and valve spring combinations as well as diagnose valve train issues using a spintron. So I pulled the heads and sent them to Katech for their "LS7 fix" including porting, bronze valve guides, Ti/Mo intake valves and new LS7 exhaust valves, and PSI springs set for their Torquer cam among other items
The Following 2 Users Say Thank You to colorado80439 For This Useful Post:
Goosesdad (05-23-2023), syborg tt (06-19-2023)
  #114
Old 06-04-2023, 12:54 PM
The Block was bored .005 and honed, bearing alignments checked etc.
The Following 3 Users Say Thank You to colorado80439 For This Useful Post:
camcojb (06-04-2023), Goosesdad (06-07-2023), syborg tt (06-19-2023)
  #115
Old 06-04-2023, 01:01 PM
We used a set of Mahle power pack pistons, balanced the rotating assembly, replaced the lifters, all bearings and bolts
camcojb (06-04-2023), Goosesdad (06-07-2023), syborg tt (06-19-2023), waynieZ (06-24-2023)
  #116
Old 06-04-2023, 08:23 PM
Hand filed the rings, HD timing chain, new oil pump. The bottom end is stock GM except the Mahle pistons.
camcojb (06-04-2023), fleetus macmullitz (06-26-2023), Goosesdad (06-07-2023), syborg tt (06-19-2023)
  #117
Old 06-19-2023, 04:34 PM
Default Bump Stick
Based on Katech's torquer cams I had Comp cams grind a cam with 114 LSA. I felt the 110 torquer was a little too aggressive and Katech's 116 LSA not enough
214Chevy (06-22-2023), camcojb (06-19-2023), syborg tt (06-19-2023)
  #118
Old 06-25-2023, 04:43 PM
Default Head Assembly
Final head assembly with installation of a CHE trunnion set
camcojb (06-25-2023), fleetus macmullitz (06-26-2023)
  #119
Old 06-25-2023, 05:39 PM
Nice parts.
The Following 2 Users Say Thank You to camcojb For This Useful Post:
colorado80439 (06-27-2023), syborg tt (06-25-2023)
  #120
Old 06-25-2023, 07:52 PM
syborg tt's Avatar
That is going to be a bad ass motor
marty-mj
