Old 04-05-2023, 08:39 AM
ScotI ScotI is offline
Been there done that with the Motor in my car also.
I had it built by a very reputable Engine builder (withholding the name is hard) and let's just say they "F" everything up that they could. From missing the timing chain tensioner, valley cover bolts finger tight, intake manifold bolts loose, head bolts so tight we needed a breaker bar to remove them, and I won't even talk about the main bearings. In the end I had to completely redo the motor including all of the bearings. I had asked them to change the cam bearings and those were also not done.
I have to ask.... Why not share the name? Seems that might help others.
Old 04-05-2023, 12:51 PM
syborg tt's Avatar
The guy was let go and about the time I was suppose to be sending my motor back his father passed away. In the end I took care of it locally and now I know everything has been corrected. If you look in my build thread you will be able to find out who built the motor way back in 2012.
marty-mj
Old 06-16-2023, 06:55 AM
68454RS's Avatar
68454RS 68454RS is offline
I haven't been doing much on the '33 but finally got back on it and got the rear end all buttoned up. Had Ridetech make me some upper and lower arms with "R" joints, BMR housing swivel bushings, cleaned and painted the calipers, new rotors and pads and all that's left is to bleed the system.
20230611_182957 by F G, on Flickr
20230611_183028 by F G, on Flickr
20230615_181325 by F G, on Flickr
20230615_181304 by F G, on Flickr
20230615_181347 by F G, on Flickr
The Following 3 Users Say Thank You to 68454RS For This Useful Post:
camcojb (06-16-2023), Goosesdad (07-07-2023), syborg tt (06-16-2023)
  #44
Old 06-16-2023, 06:58 AM
68454RS's Avatar
Of course I had to see what the new rims looked like on there
20230615_191516 by F G, on Flickr
20230615_191523 by F G, on Flickr
20230615_191538 by F G, on Flickr
  #45
Old 06-16-2023, 09:00 AM
syborg tt's Avatar
Looking good and I understand trying to make time to work on these projects is sometimes very difficult.
marty-mj
68454RS (06-16-2023)
  #46
Old 06-16-2023, 11:17 AM
Great wheel choice.
68454RS (06-17-2023)
  #47
Old 07-07-2023, 07:28 AM
68454RS's Avatar
Got the kids out of detention yesterday so now to get them reattached and back in the chassis. Both were new rebuilt E-bay purchases by the previous owner and came with the car. Both needed rebuilt. Trans guy found a bad bearing, bad bushing, bad pump housing. Had him install a TCI constant pressure valve body while he was in there and I got a Boss Hog 3200-3500 converter for it. Engine had bad valve guides and bent valves, sloppy main caps and a lot of crud in the oil galleries. Almost $4500 later, it's all done and done right this time.
The Following User Says Thank You to 68454RS For This Useful Post:
camcojb (07-07-2023)
  #48
Old 07-07-2023, 09:18 AM
dhutton dhutton is offline
Nothing’s ever easy with you Frank, is it?
  #49
Old 07-07-2023, 09:37 AM
68454RS's Avatar
Old 07-08-2023, 12:35 PM
68454RS's Avatar
I always try to test fit things before getting in too deep, just like i'm sure a lot of you do. I previously mentioned "When cranking it sounds like the starter and flywheel and torque converter don't like each other." Well, it seems the flex plate and converter bolts don't exactly line up just right and he must have forced the bolts to go in creating a somewhat slight off center flex plate/torque converter alignment and it seems the flex plate is a little warped. I was really hoping to have all this back together and in the chassis this weekend but looks like i'll be waiting on a new flex plate.
camcojb (07-08-2023)
