Old 06-30-2022, 10:23 AM
dontlifttoshift's Avatar
If that's park, it looks fine, what about the transmission side?
How many bends in the cable? How tight is the bend radius? How is the alignment, does the inner cable travel in a straight line in and out of the housing?
After that, disconnect the cable from the column. Does the shifter travel smoothly? Is there slop in the shifter mechanism in the column? I fixed one a couple months back where the column had been taken apart for paint and put together by someone who was not so bright. They left a bushing out and the shift mechanism was bound up in the column.
Donny
Old 07-01-2022, 12:41 PM
vet57air's Avatar
vet57air vet57air is offline
One bend in cable about 14" radius. Cable is close to straight in and out. Disconnected cable at trans and moved shifter though its motion. Very smooth with little effort. I did find the niloc nut attaching cable to shift lever on trans tighter than it needed to be. No question, when I move the shift lever by itself at the trans it takes more effort to go from Park to reverse than other positions. Found the separate switch for prndm linkage a little stressed. Unstressed and now fine.
Old 06-22-2023, 04:08 PM
vet57air's Avatar
So have about 2600 miles on my truck. Other than the faulty mode switch in the tranny all has been good. Anyone have luck with HP tuners to make changes to a "connect and cruise" package? I have read of many issues people have had with the 8L90 transmission (class action lawsuits). So far so good but I have decided to flush mine with the latest recommended Mobil 1 LV HP blue label fluid, just to be safe. Anyone know off hand which of the two trans cooler lines is in/out?
Pic of my truck
The Following User Says Thank You to vet57air For This Useful Post:
fleet (07-01-2023)
  #44
Old 06-23-2023, 09:24 AM
I would think that the port towards the front of the vehicle is hot oil out to the cooler. Matt at Sled Alley could tell you, he just fabbed up trans cooler lines on an 8L90E for Charley's 67 Camaro.
https://lateral-g.net/forums/showpos...&postcount=371
Old 06-30-2023, 11:34 AM
vet57air's Avatar
For your interest the front port is out to cooler. I disconnected the rear port to do my flush so it flushed the cooler also. All flushed with the new improved fluid.
The Following 2 Users Say Thank You to vet57air For This Useful Post:
camcojb (06-30-2023), dhutton (07-02-2023)
  #46
Old 07-02-2023, 04:11 PM
vet57air's Avatar
So I splurged on a couple credits for my HP tuners. Once all said and done, I can change the E92 ecu and the t87 tcm. Have several friends that have the same drivetrain combo and they have the same complaint, rpm's to low around town (1000 rpm@30mph). Changed the part throttle shift schedule to now where rpm's are in the 1500-1900 range around 30-40mph. Much happier.
  #47
Old 07-02-2023, 06:43 PM
That's the biggest advantage of the electronic trannies. Since you've got all the time driving it, makes sense that you do the tweaking. Well worth the investment.
