Old 09-03-2023, 10:32 PM
syborg tt's Avatar
Default Final Battery Ground Cable (( 09-02-23 ))
Time to build the final ground wire and I have way to many wiring connectors.
While the mock up battery was in the car I estimated the cut length of the cable.
Looks good
This was the point when I should have swapped to the Black Anodized tray.
Confirming
Crimping with my helper.
Heat Shrunk cable end.
Confirming the gap.
I enlarged the holes to allow some wiggle room.
Time to make some battery bolts. You can see that I used a shouldered nut and grimmped that in the vice and then I installed
the bolt and tightened it. At this point I can cut the bolt and not damage the visible nut.
I also shortened the acorn nut to it didn't poke into the bottom of the battery case.
Since the negative cable is close to these two nuts I swapped them out.
Much better looking and of course they won't damage the ground wire.
If you look at the ground wire you can see I wrapped it in DEI Abrasion wrap.
Tray is in.
Support Rod is in.
marty-mj
fleetus macmullitz (09-04-2023)
