Closed Thread
Old 10-22-2023, 08:05 PM
carbuff's Avatar
carbuff carbuff is offline
Mark,
A couple of quick questions about that intake setup...
What throttle body is that?
Is the air cleaner base bolted between the throttle body and intake for mounting?
And finally, does it clear the fuel rails without a spacer?
I used that same intake manifold and fuel rails, and I struggled with making a Trans Am shaker base fit. Wish I had thought of this idea. Very slick! I do prefer a cable connection between the throttle pedal and TB though - not a big fan of the DBW setups in the cars I have driven. Presumably with a good tuner it shouldn't be an issue though.
  #122
Old 10-22-2023, 10:36 PM
jeff71 jeff71 is offline
Correct me if I’m wrong Mark, DBW for cruise control?
  #123
Old 10-24-2023, 08:19 AM
Stielow's Avatar
Stielow Stielow is offline
Mark,
The 90 mm throttle body is off a LS3/7.
The DBW set up allows cruise control, tunable throttle progression, no linkage and no idle air control motor.
With some tuning it feels good, or I’m used to it.
I also hate the feel of cables and solid mechanical linkage is problematic.
The new LT torque base engine cals do have poor throttle response. It can be calibrated to be better but not as good as the PFI cals.
Mark
Stielow Engineering
fleetus macmullitz (10-26-2023)
  #124
Old 10-25-2023, 01:22 PM
Stielow's Avatar
Seat pans are in for good after the transmission cross member reinforcements were installed
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
fleetus macmullitz (10-26-2023), syborg tt (10-25-2023)
  #125
Old 10-25-2023, 01:24 PM
Stielow's Avatar
Filled a few things on the firewall. We are using Vintage Air so no need for blower motor hole.
Stielow Engineering
The Following 3 Users Say Thank You to Stielow For This Useful Post:
camcojb (10-25-2023), fleetus macmullitz (10-26-2023), syborg tt (10-25-2023)
  #126
Old 10-25-2023, 01:26 PM
Stielow's Avatar
Moved the driver side quarter panel back to the stockish location. It was pushed out 3/4 of an inch when is was a drag car. Looks like a sled hammer deal. Matt fixed it.
Stielow Engineering
  #127
Old 10-25-2023, 02:32 PM
syborg tt's Avatar
Wow this car has some beautiful patina
marty-mj
  #128
Old 10-25-2023, 04:57 PM
Aschle's Avatar
Aschle Aschle is offline
I am very interested in the transmission crossmember. You can see the tabs poking through the floor, and the mount itself... Can you shed light on what the topside looks like? I would love to get ideas for my own car.
Beautiful build as always !!!
Jason
Jason Aschle
________________
1969 Camaro
1957 Chevy 150 Utility sedan, semi-pro touring
2016 MB s-AMG E63
  #129
Old 10-25-2023, 06:08 PM
Stielow's Avatar
Jason
This is with the seat pan off.
Stielow Engineering
camcojb (10-26-2023), syborg tt (10-26-2023)
  #130
Old 10-25-2023, 06:19 PM
Stielow's Avatar
We have done this trans mount before on 4 Camaros. No issues so far. Makes a super clean set up.
Stielow Engineering
Closed Thread
