11-17-2023, 04:10 PM
“I am pretty sure it was Mark that said this. If you have an hour to spare head out and do one of the small projects. I installed
a Burn Out Switch to prevent my friends from doing a burn out when I am not around.”
MJ,
I’m guessing it will also stop the wife & kids, the family dog, nosy neighbors too?
The Following 2 Users Say Thank You to fleetus macmullitz For This Useful Post:
11-20-2023, 01:35 PM
Drivers Side Door Panel (( 11-12-23 ))
I started working on the drivers side door panels
The table is back out and so are my daughter towels from when they were little.
Looks like I need four more clips
I placed the template on the door and started trimming the panel to make them work.
Way off
This is a very tedious task so be patient.
More interior parts
The Following 4 Users Say Thank You to syborg tt For This Useful Post:
12-12-2023, 04:49 PM
Seat Belt Planet Harness / Ride Tech Roll Cage (( 11-20-23 )
12-12-2023, 05:03 PM
Classic Industries Door Panel (( 11-26-23 ) Part 1
Time to install the Classic Industries Door Panel.
I ran the factory screws in from the backside so they would make a mark on the door panel so I can punch a hole. I used
the tape to give me a reference so I new where to push on the panel.
Enlarging the holes for the blind nut.
Don't tell my wife I borrowed this.
Little paint and primer in one.
Test fitting the Template
Nailed it !!
Next up the door handle.
Final trim
I installed these washers in between the door panel and red door pull.
12-12-2023, 05:15 PM
Classic Industries Door Panel (( 11-26-23 ) Part 2
12-12-2023, 05:19 PM
Yet another list (( 11-28-23 ))
Well, it was a good run and it looks like the Harbor Freight tool was only able to do a few dozen nutzerts.
I have one bolt left, maybe I will make a keychain with it.
12-12-2023, 05:21 PM
Ugh, Trans is leaking (( 12-01-23 ))
Yep, just one more thing to worry about.
12-12-2023, 05:38 PM
Time to finish the drivers door and the To Do List (( 12-01-23 )
Thank goodness I bought that panel popper.
Fixed !!
I am not the person that made that brutally awesome hole in the door and I have no intention of removing it as it part of the cars history.
Loose bracket fixed !!
A little Eastwood Patina sauce in the door.
Installing the water shield hopefully for the last time.
I traced the water shield so I know where to install the caulk strips.
Next time I will look for my little roller.
Calling it a night.
12-13-2023, 01:36 PM
Enjoyed seeing your work…great update MJ.
The Following User Says Thank You to fleetus macmullitz For This Useful Post:
12-14-2023, 10:42 AM
Door Panel is finally on (( 12-02-23 ))
Here we go and I hope this is the last time I have to take it on and off.
These Classic Industries Door Panels are so nice.
Since the trim isn't on the Jam I tapped it off to protect the door panel.
Since the car is on the right right side of the lift ramps I decided to hang a kneeling pad on the wall to protect the door.
