Closed Thread
Old 01-04-2024, 01:59 AM
srode1 srode1 is offline
Matt at Sled Alley made a very cool mount for the new unit.
made from scratch or modified one from VA? They could market those I'd guess.
  #222
Old 01-04-2024, 05:58 AM
Stielow's Avatar
Stielow Stielow is offline
He modified the VA supplied brackets.
Stielow Engineering
  #223
Old 01-05-2024, 11:53 AM
Stielow's Avatar
Some assembly required….
Stielow Engineering
The Following 7 Users Say Thank You to Stielow For This Useful Post:
camcojb (01-05-2024), carbuff (01-05-2024), fleet (01-05-2024), Goosesdad (01-08-2024), jarhead (01-06-2024), Roscoe03 (01-12-2024), syborg tt (01-05-2024)
  #224
Old 01-05-2024, 03:28 PM
Stielow's Avatar
a
Needs a slightly shorter air cleaner.
Stielow Engineering
The Following 5 Users Say Thank You to Stielow For This Useful Post:
dhutton (01-05-2024), fleet (01-06-2024), Goosesdad (01-08-2024), Roscoe03 (01-12-2024), syborg tt (01-05-2024)
  #225
Old 01-05-2024, 06:04 PM
syborg tt's Avatar
I am really looking forward to the next set of pictures as I love to see what you guys come up with next.
Inspiring work as always
marty-mj
130fe (01-06-2024), jarhead (01-06-2024)
  #226
Old 01-06-2024, 12:09 PM
F'in mine's Avatar
What I learned on the Gen 5 Camaro Z/28 program is the LS7 works better if you keep the oil cool. This Earls oil cooler maybe a tad too big put I had it on the shelf. Im also using an Innovative Eng thermostat to regulate the temp. For a cruiser I chose the 210F thermostat.
You really want to get the oil temp up to 212F to help get the water out of the oil when you are just cruising around.
Mark, in your earlier post above you mention using a 210 degree thermostat & getting the temp up to 212 to get the moisture out of the oil when cruising around, I pressume you're talking about engine temps and not trans temp?
If that's the case general question regarding engine cooling, could you set the record straight & let some of us know what the fan settings you would recommend using dual fans and a 187 degree thermostat for our street cars using LS engines putting out around 500hp, N/A, wet sump. Thanks in advance.
1969 Camaro SSRS
Simon
  #227
Old 01-06-2024, 04:08 PM
Stielow's Avatar
It is a good idea to get your engine oil temp up to above 212F to get the moisture out of it.
We did a project at work that always had very low oil temp with poor PVC. Water condensation in the engine caused rust on the rods and the valve springs. Since then I always wanted a good PVC system and hope to get the oil temp up for general cruising.
I usually do PWM fans so they ramp in. We usually turn them on at 190 and are full power at 220F. I’ll need to look at an old cal to confirm but that seems close.
I hope that answers your question.
Mark
Stielow Engineering
The Following 3 Users Say Thank You to Stielow For This Useful Post:
F'in mine (01-07-2024), fleet (01-06-2024), Goosesdad (01-08-2024)
  #228
Old 01-11-2024, 05:40 PM
Stielow's Avatar
More induction photos
Stielow Engineering
  #229
Old 01-11-2024, 05:45 PM
Stielow's Avatar
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
camcojb (01-11-2024), Roscoe03 (01-12-2024)
  #230
Stielow's Avatar
Remote coils
Stielow Engineering
Closed Thread
