Old 01-11-2024, 05:15 PM
colorado80439 colorado80439 is offline
Default LT4 Vs. LS9
I've toying with the idea of doing 1st gen Camaro build with Detroit speed subframe etc with either an LT4 or LS9. I'm trying to gather facts of fitment issues between the 2 engines such as hood modifications, fuel delivery, power steering pump, vacuum boosters, supercharger cooling, front drive systems, headers, electrical and probably a long list of things that you don't see until you get there. Also would consider an LS3 with low profile supercharger to avoid hood fitment issues. Let me know if you would share your experience with these secondary fitment issues
Old 01-12-2024, 09:10 AM
bk2life bk2life is offline
Originally Posted by colorado80439 View Post
LT4 or LS9 Also would consider an LS3 with low profile supercharger
how much power do you need, and what type of car are you building for what type of driving...
looks only, car show killer, or something actually going to be used and abused?
Old 01-12-2024, 11:28 PM
Pretty much all of the above, small amount of road coarse time, street and cruising on canyon roads, distance trips a little bit of show. I'm at 7500ft so N/A take a back seat, 6-700 horse similar torque
Old 01-12-2024, 11:50 PM
My big concerns are fitment and drivablity issues, what difficulties are there with fuel management of LT4 vs LS9, who has a front runner with power steering that works, supercharger efficiencies and/or cooling issues, ecm looks like the LT4 is more involved with electrical control, vacuum pump are they needed for a DSE brake booster and if so who makes one thats not loud and obnoxious
Old 03-08-2024, 08:07 AM
thedugan's Avatar
thedugan thedugan is offline
Jeeze, LS9 short blocks are worth big bucks these days....
https://sdparts.com/i-24507973-chevr...ong-block.html
I hope it's just a typo where the 9 key was sticking.
Doug L.
68 Camaro RS/SS Conv. LSA/T56
67 Camaro RS LS2/T56 "NutKse"
The Following 2 Users Say Thank You to thedugan For This Useful Post:
130fe (03-11-2024), camcojb (03-08-2024)
Old 03-08-2024, 09:38 AM
samckitt's Avatar
samckitt samckitt is offline
$100,000! Can't be right.
Pace Performance has it for $13,556.xx
https://paceperformance.com/i-622022...ance-6-2l.html
Why do you only get 6 ignition coils?
Scot
86 Monte SS
LS2/T56 Magnum
The Following User Says Thank You to samckitt For This Useful Post:
Old 03-08-2024, 09:51 AM
I'd guess they have the three coils already mounted to the covers in engine assembly. They leave out the far left coil as it covers a valve cover bolt, the others don't. They throw the other two coils in a box. Kinda lazy but I get it lol.
samckitt (03-08-2024)
Old 03-09-2024, 04:33 AM
srode1 srode1 is offline
As far as fitment the LT4 high pressure pump will mean you probably need to modify the firewall for clearance, for the pump and the electrical connections. That's the price of direct injection vs port injection. I'm sure you've read the other technical differences and that the LT4 has more torque earlier making for a flatter power curve too which is an advantage in any application IMHO. The wiring on the LT4 isn't really complicated, just plug stuff in and it works and it's gone in lots of cars so there's plenty of information on front runners.
The Following 2 Users Say Thank You to srode1 For This Useful Post:
camcojb (03-09-2024), fleetus macmullitz (03-18-2024)
Old 03-18-2024, 03:11 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
What happened to the 69 LS7 build? Wasn't it in paint late last year?
Curtis
Old 03-18-2024, 08:49 PM
rpol78 rpol78 is offline
My understanding is you have more ECM options with the LS and more options for making changes. I do like the LT4/LT5 engine with the direct injection. It just depends on what you want to do in the future.
Hmmm... Makes me wonder what my LS 396 engine is worth (LS9 block/LS9 CNC heads, Callies Magnum custom crank, Callies Ultra rods, JE custom pistons, Kong 2650).
FWIW - This is going in a '67 Chevelle.
The Following User Says Thank You to rpol78 For This Useful Post:
camcojb (03-18-2024)
