Old 02-21-2024, 02:20 PM
dhutton dhutton is offline
Originally Posted by cpd004 View Post
This is where we are after back-and-forth emailing.
I sent them pics of the exhaust clearance, motor mounts and trans mount. Now they are saying I need to cut the tunnel out and raise it! I bought this subframe because it required NO cutting or welding of any kind to run the engine and trans I had.
After that, in addition to the 4 below and one above the trans mount, I have to add an additional 1/2" of shims!!
The whole tunnel or just under the transmission?
Old 02-22-2024, 01:56 AM
cpd004's Avatar
cpd004 cpd004 is offline
Just the trans portion.
1971 Firebird
2017 SS
Old 02-22-2024, 06:05 AM
Speedtech sells that T56 tunnel which can be installed with screws etc if you don’t want to be welding on your car.
camcojb (02-22-2024)
Old 02-22-2024, 06:04 PM
ADY's Avatar
ADY ADY is offline
Installed this on my '68 that has a SBC and T56, I did the cutout with the finished interior, so welding wasn't an option and used 3M panel epoxy. Pain in the ass...yes, wish I had a garage that wasn't built to barely fit a 1920's car.
-Adam
1968 Camaro SS
The Following 2 Users Say Thank You to ADY For This Useful Post:
camcojb (02-22-2024), cpd004 (06-20-2024)
Old 02-23-2024, 02:05 AM
cpd004's Avatar
I see first gen tunnels. Not second.
I went with the 4l60 because they said a 6l80 would definitely require mods. I would’ve much rather had the 6l80.
1971 Firebird
2017 SS
The Following User Says Thank You to cpd004 For This Useful Post:
camcojb (06-15-2025)
Old 02-23-2024, 08:59 AM
Sorry. I’m stuck in first gen mode. It can likely be adapted to fit a second gen.
The Following 2 Users Say Thank You to dhutton For This Useful Post:
camcojb (06-15-2025), cpd004 (02-23-2024)
Old 02-23-2024, 10:39 AM
cpd004's Avatar
The reason I went with the 4l60 is because Speedtech said with that trans, I would not need to modify the tunnel like I would with the 6l80 that I preferred.
I was willing to go with that trans to avoid any tunnel work.
A CV driveshaft isn't recommended by two different shops I asked to hopefully avoid the angle issue. Both said the weight would cause transmission damage due to this.
1971 Firebird
2017 SS
Old 06-14-2025, 06:00 PM
TBART70 TBART70 is offline
Did you ever figure this out?
The Following User Says Thank You to TBART70 For This Useful Post:
