Old 04-24-2024, 09:05 AM
andrewb70's Avatar
Default 1967 Cougar Godzilla ZF 8HP70 swap
A book has many chapters, and one can argue that the Cougar story already has many chapters. Calling this chapter 2 doesn't seem fitting, as this is more like chapter 4, but whatever. Here is a link to the last few chapters:
https://www.pro-touring.com/threads/...es-and-videos)
Every journey starts with the first step, and here is the first step of this journey:
This is a 2021 7.3L Godzilla from a wrecked F250 truck. The plan is to keep the shock towers and the current front suspension setup. Engine management will be handled by the Holley Dominator ECU which will be integrated with the TurboLamik TCU that will control the ZF 8HP transmission.
I don't know how quickly this project will move, given our move to Texas in the next 60 days, but it would be awesome to have it ready for the Holley Ford Fest in late September.
Andrew
Instagram @dr__efi
I deliver what EFI promises.
My YouTube Channel
The Following 5 Users Say Thank You to andrewb70 For This Useful Post:
130fe (04-24-2024), camcojb (04-24-2024), fleetus macmullitz (04-24-2024), kwhizz (01-06-2025), will69camaro (05-13-2024)
Old 04-24-2024, 11:50 AM
ScotI ScotI is online now
I wondered if there might be a change for the motor w/the recent events/failure. I'll be watching for the updates.
The Following 3 Users Say Thank You to ScotI For This Useful Post:
andrewb70 (04-24-2024), camcojb (04-24-2024), kwhizz (05-14-2024)
Old 04-24-2024, 01:07 PM
andrewb70's Avatar
We are moving to Denton...neighbor...
Andrew
Instagram @dr__efi
My YouTube Channel
The Following 2 Users Say Thank You to andrewb70 For This Useful Post:
214Chevy (04-29-2024), camcojb (04-24-2024)
Old 04-24-2024, 01:24 PM
Andrew
I saw that previously. Not a bad choice IMHO.
The Following 2 Users Say Thank You to ScotI For This Useful Post:
Old 04-25-2024, 07:30 PM
Wow, that's a big change. Best of luck with the move and the build, Andrew. Keep us posted. Love what you're doing with your builds.
The Following 3 Users Say Thank You to WSSix For This Useful Post:
andrewb70 (04-25-2024), camcojb (04-25-2024), kwhizz (05-14-2024)
Old 04-26-2024, 08:33 AM
TomM's Avatar
TomM TomM is offline
Andrew
Welcome to the hood....
T,
The Following 2 Users Say Thank You to TomM For This Useful Post:
andrewb70 (04-26-2024), camcojb (04-26-2024)
Old 04-30-2024, 08:00 PM
andrewb70's Avatar
I have been working with TurboLamik, for the last several month, on having full integration between the Holley EFI systems and the TurboLamik TCU. What this means is that the two will be connected with just 2 wires. This applies to the Holley Dominator and HP using V6 and also to Terminator X and X Max using V3. The Dominator and Terminator X Max are optimal because they have two CAN busses and DBW throttle.
The TCU needs information in order to make shifting decisions. Namely, it needs RPM, TPS, MAP, and torque output. Those are the basic channels that are a must, however, in order to make the transmission work optimally, the TCU needs to send messages back to the ECU.
The most critical is a signal to retard the timing during upshifts. This is commonly known as torque management and all modern transmissions implement this strategy, both for smooth shifting as well as transmission longevity. It can also be extremely helpful to retard the ignition during shifts to keep the tires from spinning during hard upshifts. With a very powerful engine, it can actually be pretty dangerous to upset the car during a full throttle upshift. This feature is now working between the TCU and the Holley ECU.
Another feature that goes along with torque management is throttle blipping on downshifts. This feature isn't strictly necessary, but it too will be available, although somewhat limited, because Holley...
The TCU will also send the following information: Gear, transmission temperature, speed, converter slip, and clutch slip. All of this information will be available to be displayed on any of the Holley digital dashes, not including the 3.5" handheld.
If there are any questions, please ask.
Andrew
Instagram @dr__efi
My YouTube Channel
The Following 3 Users Say Thank You to andrewb70 For This Useful Post:
camcojb (04-30-2024), dhutton (05-01-2024), ScotI (05-01-2024)
Old 05-05-2024, 09:07 AM
andrewb70's Avatar
Progress is being made. Scored some Mast Motorsports CNC ported heads for the Godzilla.
Still exploring various options for the cam. If anyone has some recommendations, I am open to suggestions.
Andrew
Instagram @dr__efi
My YouTube Channel
camcojb (05-05-2024), Goosesdad (05-05-2024)
Old 05-05-2024, 05:34 PM
BigBronco's Avatar
BigBronco BigBronco is offline
Looking great Andrew!
Also, welcome to Texas. I hope you and your family will enjoy it. (I am also secretly excited that I can bring you cars to get tuned instead of remote whenever you may be ready for that LOL)
Excited to see the new setup and see what all you learn from the 8 speed swap.
In regards to cam stuff, I know Brian Tooley did quite a bit of cam work with the Godzilla last year. May reach out to them and see what they found out for a custom grind.
2022 F-350 Tremor | Daily Driver
1972 Nova | LSX | 6 Speed | Speedtech Suspension | C6 z06 Brakes | Forgelines
1968 Firebird | LM7 Swap | 4L60e | Ridetech Suspension | C6 Brakes
2012 Corvette ZR1 | Bolt-Ons | Forgelines
2001 Trans-Am WS6 | Cam | Six Speed | Slow
1969 Mach 1 Fastback | New Project
The Following 2 Users Say Thank You to BigBronco For This Useful Post:
andrewb70 (05-05-2024), camcojb (05-05-2024)
Old 05-05-2024, 08:49 PM
andrewb70's Avatar
I am excited to be in Texas. We should be all moved in about 6 weeks.
BTR only has their Truck Norris Godzilla cam at the moment. They did tell me that more were designed, but nothing has been tested and apparently cam cores are hard to get.
I am kind of leaning towards the MAST HO Godzilla cam. All of the MAST cams have the VVT locked out, which is what I would prefer.
Andrew
Instagram @dr__efi
My YouTube Channel
fleetus macmullitz (05-06-2024), kwhizz (05-14-2024)
