Old 07-04-2024, 11:05 AM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by jeff71 View Post
Hey Mark,
I was curious if you thought the C6 Z06 brakes would clear the Forgeline OE wheels front and rear.
Yes Forgeline can build them to fit the 6 piston C6 Z06 brakes. You will need to go to a thinner outer wheel half. I did the base slider C6 brakes to get a more “stock” look. I pulled the hub cab back as far as I could with the widest outer wheel half I could do.
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
camcojb (07-04-2024), Ketzer (07-07-2024)
