  #14
Old 08-12-2024, 01:01 PM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by jeff71 View Post
Mark, did you go with the close ratio and have D&D do the .50 swap on this build?
D&D can give you the tight ratio 1-5 and add a 0.5 6th. This works great with a blower motor with a ton of torque because it can pull the 3.25 rear gear and the OD. For this build with a stock LS7 I closely copied the 2014 Z/28 with a tight 1-6 and a 3.73 rear gear. It will turn a little bit more RPM at 80 but should drive great.
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
camcojb (08-12-2024), NAPA 68 (08-12-2024)
