View Poll Results: Which block would you choose?
Dart Aluminum Block 30 73.17%
World Product Motownlite 11 26.83%
Voters: 41. You may not vote on this poll
Old 12-20-2006, 03:11 PM
rocketman's Avatar
Originally Posted by nitrorocket
You can easily make a 427" LS2 motor with an aluminum block. That will handle all the power you can throw at it. On top of that, an LS2 head with a little porting flows better then out of the box 18 degree heads...plus it's fuel injected!!
Do what LS2 out flow 18's,Ls2's won't flow 350 cfm ported,I have set of Brodix 18's that out of the box flow 350 cfm,no port work out of the box.
Old 12-20-2006, 04:18 PM
nitrorocket's Avatar
The Brodix 18's do not flow 350 out of the box, suppose it depends on whos flow bench. All would have to be done on the same bench.
My Dart 18's flowed 330/260 @ .700 lift out of the box. My TEA ported LS1 heads flow 317/255 at only .600 lift. That is as much or more then my $4000 Dart 18 degree heads, with a factory $200 set of heads and $1200 worthe of valves and porting!
LS6 heads with porting 346/270 @ only .600 lift on a cheapy factory head!!
YOU CANNOT BEAT THAT WITH A STICK!
Twin Turbo LS1 '71 Chevelle
1000 hp 93 octane street car
6 speed
Old 12-20-2006, 04:38 PM
rocketman's Avatar
Flowed them today at 700 lift they were 350/270.
Old 12-20-2006, 04:46 PM
So you gotta admit that the ls1 heads flow big time at only .600 lift for a head with a total investment of less then $1500 bucks!!
That's what I LOVE about LS1's!
6 speed
Old 12-20-2006, 05:19 PM
rocketman's Avatar
They flow good,not bad for a street head. I have seen some killer LSX heads that flow low 400's.I did a friends Ls6 heads acouple years ago and they flowed 390 at 650.
I was just pointing out that while it is possilble to out flow out the box heads,it's going to take quit abit of port work on stock heads,Brodix heads IMO are the best for out of the box performance.and are the closet to advertised flow #'s I have seen.
Old 12-20-2006, 06:28 PM
OTE Design & Fabrication OTE Design & Fabrication is offline
Supporting Vendor
Here's a Brodix block 427 we're doing for a 3rd gen Camaro. Standard everything on the block except the rocket block style oil pan. Off the shelf parts inside except for reduced base circle cam. Brodix gives you alot of options.
Old 12-20-2006, 06:48 PM
Fastbowtie Fastbowtie is offline
What's their pricing on a block?
