Old 06-06-2021, 08:16 PM
JD67SS's Avatar
JD67SS JD67SS is offline
Originally Posted by Ketzer View Post
This is very awesomesauce....
Awesome as it stands right now... please don’t paint it white
Old 06-17-2021, 04:47 AM
srode1 srode1 is offline
Because the DSE kit is based around a 4th gen Camaro master. I just copy the 4th Gen Camaro clutch pedal geometry. I purchased a stock 1992 Camaro Clutch pedal along time before all these stuff was available so I just use it as a template.
Here is the 69 vs 1991 pedal.
Curious, did you install a top of clutch switch or bypass it with a jumper to fool the controller? I didn't see any reference or pictures on it, but might have missed it, or maybe its part of the pedal system you used.
Old 06-20-2021, 03:42 AM
Stielow's Avatar
Stielow Stielow is offline
Yes I did because I needed it for the cruise control also
Stielow Engineering
Old 06-26-2021, 06:01 PM
89 RS's Avatar
89 RS 89 RS is offline
Thumbs up
Great build Mark, always raising the bar!
Corey
1989 Camaro RS
Old 07-02-2021, 12:53 PM
I had D&D Performance tuned up my T56 Magnum. Their shop is 5 miles from my house and they are great to deal with.
Off memory replaced all the nylon sliders with brass and added better synchronizers where needed.
I also have 6th gear swapped to a 0.5 ratio to make cruising on the highway at 80 mph at around 1840 rpm.
Do you remember how you dealt with the 40 tooth reluctor ring requirement in the T56 magnum or if you used the Super Magnum with the 40 tooth ring installed? I have read some folks using HP tuner to adjust the 12 tooth ring that comes in the T56 to make it compatible with the GMPP controllers, just curious which route you ended up going.
Old 07-02-2021, 01:12 PM
randy randy is offline
Can’t just change the value to 12 tooth. Slight math involved. I’ve done 4 of them now this way. I have a post on here on what to do
Old 07-03-2021, 09:06 AM
EVIL SS EVIL SS is offline
Not sure if this helps you but, I bought one of these for my T56 magnum
https://www.ebay.com/itm/164002086493
Old 07-03-2021, 11:08 AM
how difficult is it to install that?
Old 07-03-2021, 01:03 PM
I haven't done it yet but, it looks easy. It comes with directions but, I think they post them on their ad too.
Old 07-03-2021, 01:59 PM
There's some pictures in there - look forward to hearing how it goes for you. It does look easy if it's not a press fit.
