Old 01-07-2015, 12:04 PM
Question Mark.
Do you have a picture of the dash with the Race Technologies dash in Hellfire? Do you have dimensions of that dash? What all components are you running?
I'm looking at gauge options for my car and had previously been looking at the racepak setup but like this as an alternative possibly. I'm using the Holley EFI which makes the racepak simple, but need to research more details on this prior to a commitment.
William
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 01-07-2015, 12:52 PM
I can't wait to see this!
Old 01-07-2015, 01:51 PM
wiedemab's Avatar
wiedemab wiedemab is offline
I'm not certain, but I believe he used this one.....
http://www.race-technology.com/dash2_pro_8_31379.html
BTW - - -some quick googling found a video that V8TV did that has footage of the dash.... I clipped out a picture of it for you.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 01-07-2015, 02:15 PM
Stielow's Avatar
Stielow Stielow is offline
Thanks yes that is it.
Old 01-07-2015, 10:54 PM
89 RS's Avatar
89 RS 89 RS is offline
I've got a feeling this is going to be some cool stuff.
Corey
1989 Camaro RS
Old 01-08-2015, 09:09 AM
OH YES !
Old 01-10-2015, 08:17 PM
formula88's Avatar
formula88 formula88 is offline
Removing the downbars from the front of dash (bolted) to the AM subframe (welded) proved to be a little difficult as the sawsall blades dulled quickly. The solution was the "wheel of death". The 7" diameter carbide disc on a 4"grinder is probably not OSHA approved, but it allowed for easy access to the work area and made quick work of the chrome moly tubing.
Gordon
Old 01-10-2015, 08:20 PM
Gordon --- At least Mark had the OSHA approved flame retardant coat on!!!
Old 01-10-2015, 08:34 PM
formula88's Avatar
With the downbars removed the AM subframe was lowered with a couple floor jacks.
And the new DSE subframe installed.
Mark pocketed the cross member near the RH engine mount to provide clearance for the AC compressor.
Gordon
Old 01-10-2015, 08:40 PM
formula88's Avatar
Next up, a mockup block, heads and blower were installed to check clearance to the DSE wiper motor.
Gordon
