  #13
Old 12-23-2012, 09:17 AM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by NvrDun71 View Post
Mark do you use a stock off the shelf GM clutch master cylinder? From your pics it looks like an OE 02' F-Body setup. If so have you found any issues with high RPM shifts? Also do you typically just incorporate a clutch pedal stop into the upper pedal bracket? Appreciate your insight on this.
I'm using the DSE adaptor and the 2002 F-car apply system. With the LS9 clutch and a 7000 RPM shift it works fine. I'm at the limit of the LS9 clutch. I would not use it for drag racing.
I will put the pedal stop on the fire wall.
Mark
