Camaro XV
Page 33 of 149
First
23
31
32
33
34
35
43
83
133
Last
07-06-2013, 06:32 PM
Stielow
Guys a couple updates. I had my car together at my car party so a couple shots of the car.
Mark
Stielow
Find all posts by Stielow
322
07-06-2013, 06:43 PM
Stielow
We have the Cooling "stack" in the car and the ECM and BCM mounted.
I have learned put the ECM and BCM (Fuse Block) where you can get to them easy.
Start of the inlet tube. It will flare from 4" to 4 3/4"
Mark
Stielow
323
07-06-2013, 06:49 PM
tubbed69
Mark great work as always,sure has a nice stance
1969 Camaro LS3 5 speed
https://lateral-g.net/forums/show...er+1969+camaro
https://lateral-g.net/forums/showthread.php4?t=44668
https://lateral-g.net/forums/showthread.php4?t=47676
tubbed69
Find all posts by tubbed69
324
07-06-2013, 06:51 PM
Flash68
Wider tires and stance look killer.
Do you know the front and rear new track width by chance Mark?
Flash68
Find all posts by Flash68
325
07-06-2013, 07:03 PM
fleet
Mark,
It appears lower than some of your other Camaros.
Is it, or will it be?
fleet
Find all posts by fleet
326
07-06-2013, 07:11 PM
Sieg
Really like the front bodywork, the styling below the headlights is very clean, including the fender to lower cowl junction.
Have you designed a bumper bar behind the carbon yet? Alloy or CM?
Good Work Mr. Stielow
Sieg
Find all posts by Sieg
327
07-06-2013, 07:13 PM
DaleTx
Looks great Mark... I am wondering how much weight savings with the carbon fiber parts on the front.
Look forward to more pictures on the build and info on the dry sump system install. The front spoiler looks great!
If you wait, all that happens is you get older
Mario Andretti
69 Camaro-Nutter Racing Engines/427CI LS2 sleeved/LS7 CNC ported heads/Custom cam/T&D 1.8 rockers/Manley crank/Manley H-beam rods/Weisco pistons/NRC Pro Series dry sump/Kooks/NA,92 octane,11.5:1- 672HP @ 6,900RPM, 566TQ @ 5,500RPM
Build Thread
http://ls1tech.com/forums/generation...ine-build.html
DaleTx
Find all posts by DaleTx
328
07-06-2013, 07:14 PM
214Chevy
All of that carbon fiber looks awesome. As already stated, stance is spot on too.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
214Chevy
Find all posts by 214Chevy
329
07-06-2013, 07:28 PM
Stielow
Originally Posted by
compos mentis
Mark,
We slammed it down for the car party. Not sure if we will run it that low. It is about an inch lower than Red Devil.
Stielow
330
07-06-2013, 07:32 PM
Stielow
Sieg
We will build a bumper stiffener made out of CM. It also need to reinforce the lower grill support.
Mark
Stielow
Page 33 of 149
First
23
31
32
33
34
35
43
83
133
Last
Linear Mode
Switch to Threaded Mode
09:35 AM
