Old 07-08-2013, 09:06 AM
aggie91's Avatar
aggie91 aggie91 is offline
I'm new here, but I have always liked your builds. I think the first one that hooked me as Red Witch. Then the Mule in PHR was a great car to make me want more than just a drag car. I like that you use a bunch of off the shelf GM parts on your cars.
I skimmed thru this one, but I must really read the whole thing from start to finish.
This is going to be an awsome car!
Karl
1965 Chevrolet C10
1982 Chevrolet C10 - My son's Truck - Sunburn
Old 07-11-2013, 05:57 PM
Stielow's Avatar
Stielow Stielow is offline
Matt at Sled Alley is doing a great job on the induction tube. It is 4" to 4.5" to 4.75" inch K&N MAF sensor. Going to a nice big 5 inch inlet K&N filter. We need a lot of air to make a lot of power.
Mark
Old 07-11-2013, 06:07 PM
WOW, guys make it look easy. Mad skills!
Old 07-12-2013, 04:50 PM
efs69's Avatar
efs69 efs69 is offline
Mark,
Could you post some more details on the oil tank mods when you have a chance.
Project is looking great....as usual.
Old 07-17-2013, 06:23 PM
byndbad914's Avatar
byndbad914 byndbad914 is offline
I can also fit a 11 inch wide front wheel!
Nice well made parts that fit well.
I have a 18 X 11 mocked up on the front with a PSII 315/30R18. It fits OK but it needs more backspacing than I like to maintain turning radius. I'm concerned with too much tire rubbing.
Mark, what offset or backspace are you using with the 11"?
I am in process right now of ordering nearly identical wheels (the GA3s, not the Rs, fit-wise identical designs) for my 66 Nova and am also going to use them on my 2011 Z06 that has ZR1 brakes (Carbon Edition). I could not get an 11"; I am having to stay at 10.5" because the inner barrel of the 11" hits the ZR1 caliper and the 10.5" just squeaks by. For the Vette I need to run a 37.5mm offset (~7-1/4" backspace) so if I were to reduce that by 1/2" I could run an 11", so maybe you are in the 6.5" BS or 25-30mm offset range or less?
If so, keep in mind if you want a more BS for fender clearance you will need to go to the narrower wheel at around 7" of BS. I will be running a 295 tire because the 315 can hit the inner fender stuff on the Z06, you can still run the 315 on a 10.5" wheel since you won't have that issue on the Camaro.
Old 07-17-2013, 07:31 PM
dropped72ss dropped72ss is offline
Incredible work! Car looks amazing already, can't wait to see the finished product.
Old 08-02-2013, 09:48 AM
next69 next69 is offline
Any updates for us Mark?
Old 08-06-2013, 05:48 PM
Stielow's Avatar
Matt has been busy getting the cage going.
Old 08-06-2013, 07:40 PM
coolwelder62's Avatar
Mark,Matt does an awesome job on the Fabrication.I can't wait until I get some time to have him show me the art of Leading.
Old 08-10-2013, 03:45 PM
Stielow's Avatar
Getting closer on the induction tube.
4 inch to 4.5 tube transition.
