Old 04-26-2024, 03:02 PM
dhutton dhutton is offline
Saw this
https://www.instagram.com/reel/C6KnG...RlODBiNWFlZA==
The Following 2 Users Say Thank You to dhutton For This Useful Post:
ADY (04-29-2024), camcojb (04-26-2024)
  #502
Old 09-19-2024, 08:42 PM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Long overdue update. I've kinda lost motivation to work on the car, but I'm still trying to get things progressing forward. There is some small stuff here and there thats not really important, so I'll skip some stuff and hit the major things. It looks like I left off with the fenders and front end close outs. Well, the fenders still aren't done. Long story short, I'm waiting on a guy to model them in CAD and then another guy to 3D print them for me as I don't have a big enough printer. More on that to come.
Lets start with the exhaust. I had a set of 2" headers from a well known company. Turns out they wern't even close to fitting even though they were for a Corvette chassis. I cut them up and turned them into a set of Tri-Y headers. I ran full 3" to the back with 2 X-pipes and a set of cut outs. The muffler is a Holley part that a buddy that worked for their technical team was able to get me. Its an internal crossover muffler used on the 6th gen Camaro systems they sell. The cutouts skip the muffler at the back similar to C6, and C7 Corvettes as well as 6th gen Camaros and CTS-V's work. Its all vacuum operated and I'll have a controller that opens and closes them based on throttle % and RPM as well as a manual override for full open and closed. I used Sendcutsend to laser cut out exhaust tags with my cars name and logo that also reinforce the X-pipe. Also as you can see, the tail panel has been cut out for the future home of the exhaust tips.
**Its too big of pain in the ass to put them in order, sorry**
Exhaust 98% done I started roughing in the defuser in foam. This will eventually be made out of carbon fiber.
The bottom of the hood is also 95% done
I cut up some very nice and expensive carbon fiber A-pillar moldings. After foaming and shaping to fit my dash everything was fiberglassed. The foam was cut out from the back side and then everything was body worked and primed. I don't know if I'll warp them in leather or paint them yet.
At this point the shop I was working for moved into a new shop. With that we got our mill and lathe running. Knowing I wasn't going to stay working there for too much longer I knocked out as much machine work as I had/needed. I made bushings for the core support, lift pucks, cable adapters for the doors. The throttle pedal to match the rest of the Corvette pedals, but without the crappy wobble that they are known for. Most importantly I machined a ton of stainless bolts and whats a cool looking bolt without an awesome moto inspired aluminum washer? 1/4", 5/16", and 3/8" along with some metric so the engine stuff matches. I also machined threaded bungs for tow hooks for track days that are easily removable.
I also finished my engine and mounted the mirrors.
Oh, and the supercharger received some CNC race porting just to keep things spicy.
The mock up lower radiator mounts I finally got around to making out of aluminum and getting them finished.
At this point I went to work for another shop that supports my ideas instead of telling me that most places don't do what I have in mind. Thats 3D printing. I spent a bunch of money and bought a new laptop, 3D printer setup, 3D scanner, and CAD software and then took the youtube crash corses on how to do it all. The second car part I made was a mount for my BMW soft close trunk latch, which I retro fitted into my car.
Instagram- camaroaj
The Following 3 Users Say Thank You to CamaroAJ For This Useful Post:
camcojb (09-20-2024), Goosesdad (09-20-2024), syborg tt (11-26-2024)
  #503
CamaroAJ's Avatar
The very first car part I printed and modeled in CAD was a camera mount for my Live View camera. I have this setup in my truck and love it.
So with the 3D printer now at my disposal I've been working on front brake ducts, the brake duct inlets with integrated fog lamps, hood release handle mount and dash end close out base, cold air intakes, emblem mounts, door panels, ect. All kinds of stuff that would have taken so much more time if I tried to make it out of carbon or metal. Just note these are all printed in cheap PLA for mock up. Once I'm 100% happy they everything will be printed in a higher end material depending on where its used. It could be ASA/ABS or a carbon fiber reinforced nylon.
I picked up a resin printer as well, its a warm liquid goo that hardens with UV light. I made one of my HVAC duct adapters from the C6 dash to the Vintage Air duct hose.
Instagram- camaroaj
The Following 8 Users Say Thank You to CamaroAJ For This Useful Post:
89 RS (08-11-2025), ADY (09-21-2024), camcojb (09-20-2024), dhutton (09-20-2024), Goosesdad (09-20-2024), Roscoe03 (08-10-2025), syborg tt (11-26-2024), WSSix (09-24-2024)
  #504
Old 09-20-2024, 05:41 AM
ScotI ScotI is offline
Some trick stuff w/the 3D printing & resins.
Old 09-20-2024, 06:19 AM
Awesome build. Can’t wait….
Old 09-20-2024, 06:26 AM
Old 09-20-2024, 09:48 AM
Goosesdad's Avatar
Awesome AJ
Have a great day!
John
My Build Thread:
The Following User Says Thank You to Goosesdad For This Useful Post:
camcojb (09-21-2024)
  #508
Old 09-20-2024, 12:25 PM
syborg tt's Avatar
To say I am glad that you are at a new place is an understatement. Your talent and skills are truly inspirational and thank you for sharing these and I can't wait to see more.
mj
marty-mj
The Following 3 Users Say Thank You to syborg tt For This Useful Post:
CamaroAJ (01-30-2025), camcojb (09-21-2024), Che70velle (09-28-2024)
  #509
Old 08-03-2025, 04:47 PM
CamaroAJ's Avatar
Long time, no update. Not long after the last post I wasn't really feeling myself. I've been lacking motivation on the car and a bunch of other health issues that kind of came at me all at once. Did some testing with the Doc and a few biopsies and it turns out I have Thyroid Cancer. Sucks, but at least I have a reason and I'm supposed to have surgery in the next week or so. I've still been chipping away at the car trying to force myself to get stuff done, but defiantly drag my feet most of the day.
Anyways, let me get you caught up as to where I'm at. Shifter linkage is done.
I needed a way to mount my ECM so I modeled up a mount. Final print will be out of carbon fiber reinforced nylon.
Wiring has been mostly done on the rear speed sensors, transmission, and engine harness.
With how I want to wire my car I needed a few different fuse blocks for the ignition relays and stuff not running through my Infinity Box. The left of the glove box opening on the C6 dash is a good spot and the passenger dash end it another great spot. Modeled up some mounts and printed mock up pieces.
While I had the drive train dropped out it was a good time to add some fish plates to the torque tube tunnel just for a little extra strength. I also finished out the section of floor behind the seat to the fuel tanks. On the top side I have a reinforced box so I could bolt a lift puck so I have a good spot to jack without crushing the floor or side skirts when they're bolted on. I also cut out the bottom frame filler panel to run the dry sump oil lines through.
Interion lighting has been upgraded to LED's as well mounted with more 3D printed parts.
With the wide body needing to be wider then the Anvil finders already are scanned a previously mocked up widened fender and modeled it up in CAD to be able to make a mold and mirror it for the passenger side. Lots of prints later and I have a few molds. Hit them with high build to get rid of the layer lines and blocked them out to see what is gonna need filler work before I can pull a carbon part from them.
I final print both dash ends in glass reinforced ABS and fiber glassed them into a full size panel before final shaping and bonding them to the dash. The driver side from the previous update is for my hood release.
I was originally going to 3D print my door panels, but it is a ton of work for me to figure out how to get the base of the panel to fit the door right so instead of wasting a ton of time I decided to start with a set of Fesler panels and cut them up to fit my dash and body. Needed to shorten the rear panels a lot. The front needed the speaker and center sections moved back to fit the dash. Now I can foam and fiberglass the upper section to fir the dash for better flow. From these I'll scan and model up arm rests, grab handled, and door release buttons.
Cont. below
Instagram- camaroaj
The Following 7 Users Say Thank You to CamaroAJ For This Useful Post:
89 RS (08-11-2025), camcojb (08-03-2025), fleet (08-03-2025), Goosesdad (08-25-2025), SuperB70 (08-03-2025), syborg tt (08-18-2025), Tinker (08-03-2025)
  #510
Old 08-03-2025, 04:48 PM
CamaroAJ's Avatar
I've also mounted the Gen5 HVAC case and printed up a few mounts for random modules. These hold the cruise control, duel window switch to control the exhaust, fuel gauge adjuster to adapter two fuel senders into a 0-90 GM gauge, the vacuum pump controller, and the HVAC controller.
Speaking of vacuum pump, its mounted in the driver tulip that I cut out.
The latest thing I've got modeled up is the rear diffuser. I just started printing it out and I'm doing it in such a way that I can use it as the core material for the carbon fiber final part. Pics of the printed parts next update.
Instagram- camaroaj
89 RS (08-03-2025), camcojb (08-03-2025), Che70velle (08-04-2025), dhutton (08-03-2025), SuperB70 (08-03-2025), syborg tt (08-18-2025), WSSix (08-10-2025)
