Old 04-01-2025, 10:38 PM
Good job!
Old 04-02-2025, 08:31 AM
ScotI ScotI is offline
Glad to see you're still around & chipping away @ this.
Keep the updates coming.
The Following 2 Users Say Thank You to ScotI For This Useful Post:
camcojb (04-02-2025), Roscoe03 (04-02-2025)
Old 04-02-2025, 10:06 AM
JKnight JKnight is offline
Oh yeah, still chipping away at it. Everyone here understands how much work goes into making a car that works decently. The big trunk pan replacement was a good learning experience. It turned out pretty well given it was my first panel replacement.
Cooling system needed a total overhaul. I chose to work within the confines of the 80’s custom aluminum core support. A new stock size, 3 core, Frostbite aluminum radiator was acquired and modified to hold a new fan from a modern Chevy that needed some serious cooling help. The Holley Term X ECU is controlling the C7 Z06 cooling fan via PWM, thanks to Andrew B. who set that up in the tune and assisted with initial startup.
With the exterior of this car screaming “modified”, I always liked the idea of keeping the interior somewhat stock or classic looking. But, I made some exceptions in the name of improved functionality with Dakota Digital HDX gauges (RTX wasn’t released when I purchased these), Detroit Speed wiper motor and a beautifully crafted MPI steering wheel. All were chosen to provide at least a nod to the factory style.
The Following 3 Users Say Thank You to JKnight For This Useful Post:
214Chevy (04-02-2025), camcojb (04-02-2025), Sheck44 (04-03-2025)
Old 04-02-2025, 10:53 AM
Rick’s Restomod tank was paired with a ZL1 Camaro fuel pump and corner pickups (because…why not?) and a Vaporworx controller to make the fuel system as reliable as possible. Also added a fuel vent canister, which does seem to be keeping the fuel smell to a minimum, but I did have an unexpected amount of fuel coming out of the vent when fueling up the car this weekend. Not sure what that’s about. Anyone have any ideas?
camcojb (04-02-2025), Roscoe03 (04-02-2025), Sheck44 (04-03-2025)
Old 04-03-2025, 04:58 AM
Sheck44's Avatar
Sheck44 Sheck44 is offline
Great work Jeff !
Cheers
Steve
'Build it RIGHT the 2nd time'
69' SS X11 PRO-TOURING - SOLD
73' FJ40 LS - SOLD
1966 FJ40 R2.8 -SOLD
911 Hotrod - SOLD
2002 Gated 360
Next up - "Killer Piggy"
67' Camaro - Take-Over'
The Following User Says Thank You to Sheck44 For This Useful Post:
camcojb (04-03-2025)
Old 04-03-2025, 09:20 PM
F'in mine's Avatar
Re: Fuel coming out of the vent, I noticed that you're using the LS3 or ZL-1 pump and sending unit all in one rather than the separate sending unit.
Some possible things to check.
Vented cap? Some of Ricks newer tanks have the new style screw caps that I believe are non-vented. I had to try a few reg. vented caps until one that worked properly.
The vent line in your pic looks to be tucked under the fuel feed line, I would get it up high as quickly as possible, maybe you did?
Maybe you over filled the tank and the trigger didn't get activated to stop soon enough. I try not to over fill and listen as I fill up.
The hoses going to the vent canister are in the right ports?
Gas coming from the in ground gas station tanks is cooler then pumped into vehicle gas tank will expand somewhat.
I added another tank vent boss on my filler tube at around the 1-2:00 position to help with the venting, hoping it helps and no issues so far.
1969 Camaro SSRS
Simon
The Following User Says Thank You to F'in mine For This Useful Post:
