Old 01-10-2007, 04:45 PM
Mikael A Mikael A is offline
Default Ram jet
Ok here is the deal, I have a 454 with a Ram jet and I need to know how to
and what I need to make it work with a fuel cell ,or if use the stock tank
can I make it work some how (I do paint, body and fabrication so I don't know anything about fuel systems so any help is appreciated)
tanks
mike a
Old 01-10-2007, 05:37 PM
Fotoboy Fotoboy is offline
Need high psi fuel pump 60 +, pref inside they say for cavitation but I have it mounted under with no issues.
Old 01-11-2007, 05:28 AM
So I can get a fuel cell to fab everything and then worry about the fuel system.
mike a
Old 01-11-2007, 11:59 AM
I think youll be fine, but as I always do get another opinion. My setup was done when I bougth the car. Just get as big as a cell as you can fit, 502 bbc suck gas. Check these guys out: http://www.rickshotrodshop.com/musclecartanks.htm
I have a 12 gal in the trunk and might remounting under the car.
Good luck.
Old 01-11-2007, 12:01 PM
THis may be pretty obious but make sure that you run a good reg. Its also a way to kinda cheat and mess with af.
Old 01-11-2007, 06:18 PM
Good luck.
That is a nice tank but a little to price at this point 50 grand in parts and the wife is ready to kill me so I guess a aluminum cell from summit is the way to go.
mike a
Old 01-11-2007, 06:47 PM
Huh??!!
Old 01-12-2007, 07:12 AM
Originally Posted by camcojb
Huh??!!
Fuel pressure regulator, I spent may hrs on the phone w Arizona Speed and Maine, these are the guys that designed the system for GM, they said that you could change the AF globally w increasing fuel pressure but was not the best way to do it, being a speed density system nothing would correct the sytem. The timing on the other had at wot never changes when you spin the dist., only the idle timing is changed. I have got conflicting answers with calling them mult times, but I keep in the back of my mind if i am talking to a sales man or a tech guy and take it with a grain of salt.
I want to the dragstrip andit was like 30 deg and the car was running way lean to the point that it was bucking down the strip so I increased the pressure 10 psi and it went away and ran consistant 10's after that. THis year we are puting a procharger on it so I will be switching to a xfi system or something like it.
Old 01-12-2007, 07:45 AM
pushrod243's Avatar
pushrod243 pushrod243 is offline
A lot of thought should go into your fuel system or you might spend money twice to get a system that works correctly in the end. If you search this forum there is a lot of info about injected fuel systems. One of the things you have to keep in mind is keeping the fuel cool. The pump heats up the fuel then you are pumping it to the fuel rails and returning the excess which is heated by the engine. Eventually you can boil the fuel in the lines if you have a bad system.
One solution is to run an in tank pump to help cool the pump. I like the bosch pump from a Porsche Turbo car. I got the part # from this forum. Kurt from wheel to wheel suggested it when I was having trouble with my aeromotive pump. I had Ricks build a tank with two of those pumps inside it. I had planned to put twin turbos on my car and need the second pump for the trubos. Your ramjet should be fine with one pump since that is all i use on mine without the boost.
Also fuel line and returns must be large enough to move the fuel without causing any restriction. I would suggest -8 feed and -6 return as minimums some guys might tell you -10 feed with -8 but I have -8 on my car and it seems to work fine.
You should be able to put a system together without buying a high dollar tank but you will need the right pump etc to get it done. My car is a 69 Nova with a ramjet 502. And it was boiling fuel in the return lines on the power tour in 2005 and the bosch pumps in the gas tank cured that. I did it twice so you dont have too
John
Old 01-12-2007, 08:32 AM
I understand the fuel pressure regulator it was the cheating part I didn't get! Obviously up the pressure will affect the A/F, but never considered it cheating.
And the above is why I never use an EFI system that I don't tune myself. The tune and quality thereof is the key to a good EFI system, so these "closed" systems that can't be tweaked by the end-user do not appeal to me.
