Old 01-25-2007, 06:03 PM
surreyboy
Guest
Posts: n/a
what engine size is the unit for?
Old 01-26-2007, 07:24 AM
Ricochet's Avatar
Ricochet Ricochet is offline
It is from late 80's - early 90's big block from what I remember. I forget exactly what John told me it was off of. But I know the part # is correct. I would call him to verify your application. It just occured to me that your motor is a tall deck, best of my knowledge this would not work for your application.
Old 01-26-2007, 08:59 AM
69 L88 Camaro 69 L88 Camaro is offline
Default Bs3
Don't quit on the EFI. What doesn't kill you makes you stronger. If you end up with the cam sensor Ricochet described you can cut the short deck collar off on a lathe and make a slide type for the tall deck, which is a good idea anyway. I'm sure this is not the first time Big has ran with a application such as yours.
I don't ride in it, I drive it.
Old 01-26-2007, 10:50 AM
Ricochet's Avatar
I agree, don't quit on the EFI. The part I recommended will not work out of the box with a tall deck. 69 L88 has a good idea to make it work. There are other people out there running tall decks with EFI & COP systems such as the Year One Nova, so we know it can be done. Maybe the Accel DFI is compatible with the MSD 8514 unit.
http://www.popularhotrodding.com/fea...rolet_nova_ii/
I'm sure this could be answered easily by calling Big Stuff. It's not like this is something that has never been done, it's just figuring out how to get there. I know...Easier said then done.. Just don't give up. Remember, if it was easy everybody would do it. Much like yourself, I'm not real saavy with the managements systems out there - just get hooked up with the right people who are. Your efforts will be rewarded.
Old 01-26-2007, 06:02 PM
surreyboy
Guest
Posts: n/a
thanks for the encouragement, the frustrating part is the total lack of tech info in the big stuff literature, i was reading into the xfi fast system and they are very clear on alot of aspects that big stuff glosses over.Im not going carbed but just not sure if i should stick to the bg3 or go to the fast system.
Old 01-26-2007, 06:26 PM
Default Efi
Do you already own the BS3? Might want to check the website Yellow Bullet. Some of the guys there run aftermarket EFI. Might get some answers to your questions there. I've used a belt drive for the cam and a pickup on that or used the distributor trigger with only one peg on the reluctor and a crank trigger. No DIS experience.
Old 01-28-2007, 09:06 AM
Efi69Cam Efi69Cam is offline
http://198.208.187.182/internet/View...Number=213-350
This is the cam sensor oil pump drive.
According to the AC Delco catalog, this part is for 1998-2000 7.4 gas heavy duty trucks, like Kodiacs.
It looks like a vortec dist without the cap and rotor. I had a suspision that something this existed. I saw a 7.4 vortec being torn down at a shop that had coil mounts on the valve covers.
Now the question is if GM made an electronic distributor. All the 7.4s I've seen used the vortec computer that does not have coil drivers.
Old 01-28-2007, 09:26 PM
surreyboy
Guest
Posts: n/a
thanks for the help guys, due to time constraint were going to go with a distributor at this time, figured out how to wire up the crank trigger.2 questions, will the msd dist with cam sync out work for the cam sensor? and is there a need to use a msd 7al with the bg3? if so how does it get wired in?
Old 01-30-2007, 10:38 AM
Ricochet's Avatar
This is the same unit I have - the box also has a AC Delco # on it as well as GM # I posted earlier.
Brent
Old 01-30-2007, 10:40 AM
Ricochet's Avatar
Not sure if you already have a dist or not, but I have the one that came with my crate motor from Shaver. http://store.summitracing.com/partde...5&autoview=sku
If you need one & this one will work I'll give you a smoking deal on it. If not needed - good luck, keep us posted.
Brent
