Old 03-11-2007, 09:11 PM
blazer_man's Avatar
blazer_man blazer_man is offline
Default Need airbag expertise
I am going to use airbags for the first time on my blazer. The biggest question I have is how to determine the starting point for placing the 'bags. I am using 2600# bags both F&R. What height is recommended for installation (i.e. compressed/relaxed/partially inflated). What is the impact on ride/handling by installing them behind the rear end vs on top of the rear end. Any feedback would be much appreciated.
Old 03-11-2007, 11:46 PM
novanutcase's Avatar
novanutcase novanutcase is offline
Call AirRide Technologies! They can supply you with whatever you need!!
Old 03-12-2007, 05:27 PM
prostreetamx prostreetamx is offline
Depending or your suspension type, where you put the bags will affect the travel and load capacity of the rear of your vehicle. The closer you put them to the suspension pivot point, the more travel you will have, but less load capacity. They will hold up more weight if placed farther away from the suspension pivot point at the cost of some overall travel.
Old 03-12-2007, 09:04 PM
TravisB TravisB is offline
all airbags have an installed hieght....what brand are your bags?
Kenny Davis Hot Rods
Old 03-14-2007, 03:08 PM
Supporting Vendor
If you are using Firestone bags you can check our site here:
http://ridetech.com/productinfo/dimensions.asp
Scroll down to "Air System Components" and you will see a list of recommended installed heights for the airsprings we sell.
-Britt-
Old 03-14-2007, 08:33 PM
blazer_man's Avatar
Default Thanks guys!
I got the bags from aim a while ago, I don't know what the brand is. I asked them about install details but they are more concerned with laying on the rocker panels than actual ride and handling. From what they are telling me they are supposed to go in at the "relaxed" height. Does that sound right? I am going to mount them behind the rear end with the bottom of bag approximately even with the bottom of the housing. I will definitely be getting with the ART guys later in the project for parts and advice, they come recommended from everyone I talk to (now). Any comments would still be appreciated. Thanks again for the responses, I love the great feedback on this forum!
Old 03-15-2007, 06:57 AM
kennyd's Avatar
kennyd kennyd is offline
AIM is concerned about mini trucks layin flat on the ground , for best ride and drive follow the recomendation of air ride tech . installed height is everything , go to air ride's website or get a catalog and it will have installed height for each bag .
Old 03-15-2007, 07:39 AM
Tony@AirRideTech Tony@AirRideTech is offline
Supporting Vendor
I am not sure which airsprings you got from them and I am not even sure of the specs on the airsprings that they use. You do need to get that info from them and you need to make sure that your installed ride height is set up properly because if you dont.... all you will have is a truck that goes up and down and who knows how well it will perform. The airsprings that I would run on that paticular application would be a 6957 in the front and an F9000 tapered sleeve in the rear. I would set the rear up in a 1:1 ratio with a four bar.
Old 03-15-2007, 09:07 AM
wiedemab's Avatar
wiedemab wiedemab is offline
Default My install
I am using the F9000 bags on the rear of '52 Chevy Pickup - Granted it's not on the road yet, but this may be helpful. I just used ART's dimension from their website
and made my bracketry so that at ride height the bag was at it's installed height. I think for the F9000 its like 9" or 9.5" The only other things that I checked was that the shocks limited overextension of the bags in suspension droop and that when deflated the bags didn't compress below their minimun dimension (4.5" for the F9000)
Yes, I know the shocks look to be at a horrific angle in the pic, but it's aired down - they aren't that bad at ride height.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 03-16-2007, 12:40 PM
blazer_man's Avatar
Thanks for the responses guys. After further questioning everyone on the planet, it sounds like when it comes to these systems it is really up to personal preference with respect to ride stiffness and suspension travel. The recommended installed height ranges from 5" to about 7" depending on who I ask (I even asked the local minitruck/stereo/window tint/espresso emporium guy ). What I have decided to do is basically the same thing I would do with coil overs and that is to build some mechanical adjustability into my mounting system that will accomplish the range of installed heights at my desired ride height.
A question for Tony; The bags you say you would use are lighter than the ones I have. What is the impact going to be of using the 2600# bags out back vs the 1500# units you say you would use? The front bags you said you would use are close the ones I have (2400# vs 2600#).Oh yeah, forgive my ignorance but 1:1 ratio with a 4 bar??
Some particulars on my truck: 70 blazer, mustang II front susp/tubular a arms, standard small block, 4 link/wishbone rear, sway bars F&R, tube frame front & rear.
