Old 03-30-2007, 03:30 PM
Jeremy Jeremy is offline
Frank,
I appreciate your input. As for the "hop" we are definitely talking about the same thing, although I don't think it is no where near as bad for me.
I notice it most at low speeds, especially when its cold. Above 30 mph it gets a little better, better again at 50, and I can't say I've ever noticed above 75 or so.
I re read all the posts and if I under stand now, you are refering to the inboard supports under the motor being farther outboard compared to a vette. It would be interesting to see if VBP tested the spring rate in compression and rebound. It definitely sounds and feels like it is stiffer in rebound than compression.
I am guessing you would recommend double adjustables giving me the most tuning options.
I drive mine daily during good weather and had some teeth rattling moments with the edelbrock shocks, but haven't had any with the bilsteins. This seems a little odd to me as the Edelbrocks don't control the suspension no where near as good as the bilsteins.
