Old 04-20-2005, 10:13 PM
conekiller13's Avatar
conekiller13 conekiller13 is offline
Default Caged
Denny,
Why do think Cro-Mo is not worth it? I had thought that was the standard..............I really don't know much when it comes to this though.
Dan
Old 04-24-2005, 12:31 AM
sinned's Avatar
sinned sinned is offline
Added expense. The price of steel has tripled if not more in the last 3-5 months. Tubing has gotten VERY expensive. Using good old DOM 2X.150" will save a bunch of money without sacrificing much weight (maybe 40lbs or so if that).
The other reason is some organizations that spec cage constructions do not differentiate between cro-mo and DOM so using cro-mo might not have any weight advantage (the reason for use of cro-mo is usually you can run smaller tubing with the same protection for weight savings).
I have a friend who installed a very nice cage, passed tech at almost every sanctioning event EXCEPT the one he drove 800 miles to enter. They turned him around for floor plate size. I always recommend overbuilding the hell out of everything for that exact reason.
Dennis
Old 04-24-2005, 07:51 AM
67Sally's Avatar
67Sally 67Sally is offline
Originally Posted by conekiller13
Anyone know what Scca or Silver state Regs on cages are?
The 2005 Rule Book is at their site in pdf format "link"
W.
William Rouleau
Project PonySnake
Old 04-24-2005, 12:28 PM
68protouring454's Avatar
Default roll cage
i see for 2700 b vehicles and over they require 1.75x.090 wall
what would the reason for 2x.150 ?? those are scca rules right?, also nhra says 1 5/8 dom .118 minimum wall thickness in a bend, so you would need 1-5/8 .134 to make that, if you went 1.75x.090 it would not pass nhra, would 1.75 x .150 be the best bet to be good all the way around??
jake
Old 04-28-2005, 07:33 AM
CraigMorrison's Avatar
CraigMorrison CraigMorrison is offline
On a mild steel roll cage we use 1.75"X .134". If SCCA allows mild steel (like NHRA/IHRA does) this might be the way to go.
Old 04-28-2005, 08:10 AM
Default bar
what about scca?? i read thru rules posted above and over 2700lbs it needs 1.75 x1.50?? not sure i follow will your cage pass scca,silver state etc?
jake
Old 05-01-2005, 11:35 PM
sinned's Avatar
Ahhh, and there lies the catch. That is why I recommended 2.00X.154". At that size you are only going to be gaining ~50lbs in extra weight and you are going to be guaranteed to pass any tech at any event..period.
Dennis
Old 05-03-2005, 08:40 AM
Good point............
Dan
