Old 04-16-2007, 07:44 PM
TravisB TravisB is offline
Brett what spindles are you running on the a-body? Brake package?
Kenny Davis Hot Rods
Old 04-17-2007, 08:09 PM
bret's Avatar
bret bret is offline
Supporting Vendor
We are using the Fatman G Max spindle that is approx. 2.5" taller than the oem spindle. It induces much more camber gain than the stock unit [which actually creates positive camber in compression. It will work with any A body brake package. On the 66 Chevelle we are using the "normal" Baer 12" 4 piston stuff...works really well...very balanced. On my GSX I am using the 14" Wilwood 6 piston stuff. Works great as well.
We are now including the taller spindle into the Street Challenge packages for the early Camaro and 64-72 A body.
Old 04-17-2007, 08:15 PM
I have a set of drop spindles on the front of mine but I definalty want a set of the taller spindles. I will call you guys....
thanks
