Old 02-20-2007, 08:28 AM
oldzzy's Avatar
oldzzy oldzzy is offline
Default E-Brake for C6 Z06
Just like the title says, what e-brake can i use with the new C6 Z06 brakes.
Shane
70 Olds W31 clone
http://www.flickr.com/photos/85638053@N00/
Old 02-20-2007, 10:23 PM
jeff hanson's Avatar
jeff hanson jeff hanson is offline
I had these brackets made to mount the caliper,backing plate(for original parking brake) and also hold the axle in. I am using a 12 bolt housing w/ large ford bearing ends. I used a lokar cable kit. If this will work for you, let me know, they can make a set of brackets for you. As of right now, I don't believe anyone makes anything else for this situation, but by now, who knows, things change everyday in this hobby!
Old 02-21-2007, 12:11 AM
Hello Jeff!!
Great info again! I have been thinking same thing for a while. If you can please give more pics of brackets. What do you mean at those brackets hold axles in? Like holding bolts will go thru the axle housing bracket , bearing flange and the vette part and mounts all together ?
63 Z06
Old 02-21-2007, 09:19 PM
Yeah, that's pretty much it. I'll try to get you some more pics asap.
Old 02-21-2007, 11:23 PM
ZZ4Blazer ZZ4Blazer is offline
What mounting plates are you using? What rear are you bolting these to?
I've read on the pro-tourng forum, that the C6z rears will bolt up to the LS1 rear disc backing plates with just 2 simple mods. That should give you the ls1 rear disc style ebrake as well.
Old 04-24-2007, 11:37 PM
PonchoJohn PonchoJohn is offline
Any more info on this?
Old 04-25-2007, 07:05 PM
67bird 67bird is offline
Default E-brake for C6 Z06
have you tried KORE 3? They offer a kit for 10/12 bolt rear for corvette rear brakes.
Old 04-25-2007, 10:02 PM
Hammered's Avatar
Hammered Hammered is offline
The LS1 backing plates will work, but you need a 0.7-0.71" spacer between the backing plate and axle flange for a stock GM rear. The next problem is where to mount the cable bracket.
1967 Firebird Convertible, 462, EFI, TKO
My Firebird
Old 04-25-2007, 11:58 PM
Can someone tell more about this KORE3 ?? What is it and is there a webpages etc ?
63 Z06
Old 04-26-2007, 04:41 PM
Looking for alternatives to Kore3... nice stuff, just out of my range.
