Originally Posted by PTAddict
Out of curiosity, I just weighed my newly delivered QuadraLink setup. Complete weight in the packaging, with everything except axle brackets, was 89 lb. Subtract maybe 10lbs for packaging, you're at about 80, with about 40 lb of that partially sprung. That seems to me about the total weight of a pair of steel multi-leafs, shackles, and shocks, but less unsprung weight. And obviously, more than a pair of composite leafs with shackles and shocks.
Coils and shocks: 13 lb.
Control arm and panhard mounts: 16 lb.
Control arms and panhard bar: 31 lb.
Shock/coilover crossmember: 29 lb.
This is interesting.
So that works to about 30lbs of unsprung weight, and add another:
38lbs (roughly) - Ford 9" axle housing
18lbs (roughly) - Axles
71lbs - Limited slip diff
45lbs - Aftermarket discs
Equals about 200lbs of unsprung weight, which isn't bad. Obviously I'm not including 100lbs for tires, wheels, hardware, roll bar, etc. But this should be good to compare.
For a composite leaf:
172lbs -Axle housing (same as before)
4lbs - Spring bads
3lbs - Shackles
10lbs - Springs (half of total spring weight, some controversy here)
Total of 189lbs. So, we save about 11lbs of unsprung weight. Not a whole lot, and personally, if cost weren't an issue, I'd trade this weight for the adjustablility of a link suspension (I think). We'll see when the car is pushed to the limits.
