Old 05-10-2007, 08:59 PM
jsconiers jsconiers is offline
Default 67-69 firebird camaro rear disc brakes & brackets
I have a used rear disc brake kit and brackets. This is everything you will need to mount the brakes to your 12 bolt or 10 bolt and use your emergency brake. The brakes are off of an ls1 4th gen camaro and includes the emergency cables, rotors, calipers, etc. Comes with a new, unused mounting bracket from BRP for use with your rear end. $300 or best offer. Brakes located in Chicago, IL.
