Old 05-11-2005, 08:15 AM
nvawgn's Avatar
nvawgn nvawgn is offline
Default need help with 68 camaro front clip.
here lies the problem, i know nothing about camaro's and the clip is on a 41 ford w/ pwr steering, 383/350 combo, 12 blt posie year (MY DAD'S CAR).
we put new tires and wheels, new springs and had it aligned at the shop a while back and the poblem is the car grabs all the grooves and bumps in the road, from left to right and back and forth, it's like the car is looking for somewhere to go except straite. i have tried inflateing and deflating the tires a few lbs but that didn't work.
my question is on a budget can you guys suggest some parts and pieces that would help the car to feel more secure, drive better, handle better. in no way is this a lateral-g car but right now the car is kinda dangerous.
thanks, kurt
Old 05-11-2005, 10:08 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
I am not sure I understand. Is this a Camaro subframe under the 41 Ford body?
The problem you have stems back to with a worn part (tierod, drag link, pitman arm, ball joint, or wheel bearings), assuming the aligment is correct. If there is not enough CASTER the car will wonder all over the road including incorrect toe in, etc.
First go back to the basics and make sure there are no worn parts. Second, it needs to be set up and measured on an aligment rack, or right at home using strings, straight plates, and a level.
Old 05-11-2005, 11:23 AM
nvawgn's Avatar
sorry about my confusing post, but yes you are right on the button, there is a 68 camaro subframe under a 41 ford body.
thanks for the post 69myway, i just called pure vision here in simi valley california to see if i can make an appointment to check that stuff. i will definatley bring up everything you mentioned to see if we can get it right.
Old 05-11-2005, 12:19 PM
Musclerodz's Avatar
Add more caster, ie tilt the spindle backwards. That will help. How did they set it up? To a 41 truck, 68 Camaro? How much rake to the truck? Any play in the steering system? I know my camaro and my late model truck both wandered around before I rebuilt everything.
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 05-12-2005, 08:26 AM
nvawgn's Avatar
thanks for the help musclerodz, the car is a 1941 ford buss. coup with a 68 camaro front clip and 12 bolt rear end. the chassis has been cross braced and welded up like a son of a gun. there is a little play in the steering system, we just installed a new colum a couple of months ago. before we put the new tires and wheels on there was alot of rake in it but i think that was to do with the large rears and small skinnies that used to be in the front. with the 18's it sits better, could that be the part of the problem, to much rake?
Mike
Old 05-12-2005, 09:38 PM
Musclerodz's Avatar
With alot of body rake, it could be causing the spindle to sit more vertical than it should, thus loosing its desire to want to center itself. Add loose steering, and it could be a hand full. Adding more caster to compensate will help the problem but may not fix it.
Mike
Mike Redpath
facebook page
Old 05-20-2005, 07:49 AM
Steve Chryssos's Avatar
Guldstrand Mod
________________
Steve Chryssos
Ridetech.com
