Old 05-24-2007, 03:54 PM
GBodyGMachine's Avatar
GBodyGMachine GBodyGMachine is offline
Default GBODY GMACHINE Update with Pics
Hey guys. Things have been moving rather slow. I keep running out of money so it is hard to make any real progress. I did get the rear end in though. It took a little time but it fits well and the coil overs look great too. Next I am going to put the front clip back on, thats free. Then I want to get the front brakes complete and hopefully set the car on the ground for the first time on 18's.
Jeff
84 Regal Project GBodyGMachine
[SIGPIC][/SIGPIC]
Old 05-25-2007, 04:12 AM
deuce_454's Avatar
looks sharp.. what are you running for brakes, and what is involved in getting them on.. and, there sure is a lot you can do without breaking the bank.. ive had to learn paint and prep on account of a projetct and the budget conflicting..
how are your front brakes comming btw?
Jake: Hit it.
Old 05-25-2007, 04:14 AM
I received an I M yesterday asking what the setup was.
I am running double adjustable upper control arms from Ebay as well as double adjustable lower control arms from Ebay. I cut out the orig spring pockets off the frame and put in my own crossmember and bracing. I made the coilover brackets for the axle out of 1/4" steel and welded them on. The Coilovers are from Strange with 200lb Hypercoil Springs. I really like them. The brakes are from SSBC and are ment for a 12 bolt from an A-body, but I made them fit.
Any other ?'s please ask.
Jeff
[SIGPIC][/SIGPIC]
Old 05-25-2007, 04:42 PM
Duece.
The rear brakes are from SSBC. The were a freebie from a friend with an a-body. I just had to modify them a little bit to make them fit correctly. Front brales are at a stand still until I purchase the Calipers and Brackets.
How is the Bu coming?
Jeff
[SIGPIC][/SIGPIC]
Old 05-26-2007, 03:37 AM
deuce_454's Avatar
the bu is comming allong nicely... except the shop where is is recieving paint set fire to the underdash wireing, so its been there a while getting new electrics... also there will be a few things to iron out once its in my hands again, for example... rear sway bar didnt go on and i dont have a rear brake setup yet... and the LS engine swap, and turbo as you know first hand (not sure it wont hit the hood btw).. and a myriad of other things...
Jake: Hit it.
Old 05-27-2007, 09:22 AM
Man, thats looking great. That car is really going to move. Cant wait to see it done.
JEff
[SIGPIC][/SIGPIC]
