Old 06-12-2007, 10:03 AM
provertstang's Avatar
provertstang provertstang is offline
Question PCV vent system
Looking for a cool set-up for a PCV/breather. Something like a circle track set-up. I have sheet metal valve covers without holes. I have seen a set-up with 10an bungs welded in the valve covers and braided lines going to the rear of the motor with a horizontal aluminum tank mounted to the firewall. A 10an fitting in each end of the tank with 2 K&N breather filters on the top.
Does this make sense?
Pictures of your custom set-up would be greatly appreciated.
Thank you,
Brent
Old 07-03-2007, 08:38 PM
rocketman's Avatar
I havent seen a firewall mounted breath what I do is plumb it to the collector and let the motor suck it out
