Closed Thread
Old 07-04-2007, 05:32 AM
awesometool's Avatar
awesometool awesometool is offline
Default atomic orange
Five weeks away and I will finally have it back it has been a little over a year at shop. I had a hard time picking a color atomic orange is not to wild but not to plain. What do you guys think of this color and all original rs/ss trim on a 68? The 40,000 bill from body shop is a little more than I have so I will need to borrow some to pay the bill. When it comes I can start assembly and save for the hogan intake/exhaust/hydra brake and brake kit since the bear brake kit will not fit new ford rear end. HOPE TO POST FINISHED PICS AUGUST 10TH
Old 07-04-2007, 10:54 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
AWESOME!!!
Should look good.
Old 07-04-2007, 01:13 PM
slownova slownova is offline
wow 40k? i guess i didn't spend much less then that.
Old 07-04-2007, 02:13 PM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
very striking color from what I can tell from the pcis, sure to stop traffic!
Old 07-04-2007, 02:16 PM
Patrick's Avatar
Patrick Patrick is offline
Do you have any pictures of the car before you dropped it off at the bodyshop? And, do you have any pictures during the build process?
Old 07-04-2007, 06:12 PM
They installed dse fire wall, dse quadralink, dse coil over, dse subframe connectors, dse mini tubs, used roof, center trunk pan, lower tail pan, roll cage, ford 9", worked on small dents on floor, one lower center dent on sub frame, quarters the old one had many small dings. They supplied all dse parts, roof, ford 9", lower tail pan and I supplied the rest. Lucky it had very little rust. Here are some pic before it left my house and then the shop.
Old 07-04-2007, 06:13 PM
Old 07-04-2007, 06:14 PM
Old 07-05-2007, 08:40 AM
Diognes56's Avatar
Diognes56 Diognes56 is offline
Going to be awsome .
David
Old 07-05-2007, 09:20 AM
TA219's Avatar
TA219 TA219 is offline
looks great! the only think i kept on thinking is you are going to be sick if that subframe / undercarriage gets scratched while installing parts
67 Camaro
10 Camaro
Closed Thread
