Old 04-06-2010, 02:25 PM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
Default 1980 Z-28; Project Trailer Trash Treasure
Well since my dad and I have geared up and started working on his Camaro project again (he dubbed "Trailer Trash Treasure") I figured I would go ahead and post up a build thread on it.
The car is a 1980 Camaro Z-28 that I bought for him about 8 months ago (he used to own one in the 80's). I painted it the color of his old car and now we are working on building the engine for it. It will have a 5.3l LM7 out of an 04 Tahoe. Plans for the engine include and LS6 cam, LS6 intake, a set of 317 heads milled .030 off an LQ4 (w/LS6 springs), and flat top 4.8l pistons all over a stock bottom end. We are hoping to just about double the factory 190hp with this combo. It will have a 4L60E out of a 2001 Camaro behind it with a little stall in the converter. The idea is to have a factory appearing 80 Z-28 with modern drivability and power. Let us know what you guys think of the car and the progress so far. All criticism is more than welcome!
The day I got it;
Brian Miller
-1972 Nova
-1968 Camaro
-1967 C-10 step side 4x4
-2000 Dodge Dakota
it'll buff out........
Old 04-06-2010, 02:27 PM
70TWO NOVA's Avatar
body/paint;
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 04-06-2010, 02:29 PM
70TWO NOVA's Avatar
after clear...
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 04-06-2010, 02:31 PM
70TWO NOVA's Avatar
the engine stock LM7...
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 04-06-2010, 02:36 PM
70TWO NOVA's Avatar
a little cleaning...
heads cleaned and milled .030
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 04-06-2010, 02:41 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
Looking good Brian the paint is sweet as always and should be a good engine when you are done. But please dont leave your pistons on the concrete no good can come of that
Old 04-06-2010, 02:30 PM
70rs's Avatar
70rs 70rs is offline
So far so good. I like your plan for it. (and the color too).
I am curious though, can you use the heads off a 6.0 on a 5.3 saflely? I ask because I thought the valves would hit the cylinder walls since the 5.3 has a smaller bore. Or am I confused? (and that is OFTEN )
Eric
Old 04-06-2010, 02:33 PM
70TWO NOVA's Avatar
yes, you can use up to a 2.00" valve safely on a smaller 4.8 or 5.3. Its only when you upgrade to the larger valves in like the L92 heads that there are clearance issues. You have to have at least a 4" bore to run those heads.
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
