Old 03-08-2006, 06:03 PM
TOM NELSON TOM NELSON is offline
Default 1482 hp small block chevy for hot rod
We just finished David Frieburgers twin turbo small block for project f-bomb we plan to run this car at drag week.The motor made 1025 hp and 980 ft lbs on 91 octane and 1482hp at 5600 rpm and 1441 ft lbs of torque.we actually had about 200 hp more in the motor but the 83 lb injectors were stuck open at that point.This is is a totally streetable combo as a matter of fact the cams advertised duration is 266 seat to seat.We got a ton of video during the testing.we made over 31 pulls above a 1000 hp.I'm going to convert the video and post it when were done.Nelson Racing Engines
Old 03-08-2006, 06:08 PM
Default 1482 hp sbc
more pics
Old 03-08-2006, 06:19 PM
camcojb camcojb is online now
very cool Tom.
Old 03-08-2006, 06:51 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Awesome. Just awesome. Can't wait for the video.
My LS7 69 Camaro
Old 03-08-2006, 07:46 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Wow, man. I just soiled myself.
Jim
Old 03-08-2006, 07:49 PM
XcYZ's Avatar
Tom, how much boost and total timing for both the 91 octane pulls and the all out pulls on the dyno?
My LS7 69 Camaro
Old 03-09-2006, 09:47 AM
Default 1482 Hp Sbc
The Motor Made 1025 Hp At 14 Pounds Of Boost And 32 Degrees Total Timing.5900 Rpm 1482 Hp At 29 Pounds Of Boost And 32 Degrees Timing 5600 Rpm.but Trust Me When You See The Video When The Motor Hits Beyond 1000 Hp It Jumps The Hp So Fast Its Hard To Read The Gauge It Would Have Made 1600+ But The Air Fuel Would Go From 11 To 1 To 13 In A Heart Beat So We Kept Having To Shut The Run Off Early.the Goal For David Was To Make A Streetable 1000 Hp And We Did That On Pump Gas .he Was Stoked.
Old 03-14-2006, 04:33 AM
Turbo Deuce Turbo Deuce is offline
Nice power! I read pump gas, but I see 32 degrees of timing at 29 psi. Can you go into a little detail? That seems high on C16, and I read pump gas.
67 Chevy ll
Old 03-14-2006, 06:45 AM
syborg tt's Avatar
the more i read about you the more i am considering sending you my v6
marty-mj
Old 03-14-2006, 08:04 AM
Speedster's Avatar
Speedster Speedster is offline
Marty -
I would highly recommend sending Tom your V6. You will be happy you did. Tom makes "good" power, meaning high and long term.
-Bruce
Project "Freebird"
Dyno Video
http://www.nelsonracingengines.com/...lownbbchigh.wmv
Project Rides:
1968 Firebird - Blown 540
1987 Blazer 4x4 - Blown 355
2007 Magnum
2010 Camaro SS - LSX Twin Turbo
