Old 10-27-2012, 01:49 AM
Default Project G5.R
Edit: This has become more of a built thread then originally intended.
So I figured we add pictures of the car also.
Hey guys, though I'd post a few pics of my sons project. It's a Gen 5 Camaro SS hes been working on.
On the performance side:
It's been bored and stroked to a 418, 11.4.1 compression, heads massage by Lingefelter, GT11 Lingenfelter cam, CP pistons, Lunati crank and rods, Meizire Electric water pump, Innovators West 8 rid front drive, Turn One power Steering pump, Every freakin bolt inside and out has been replaced with ARP, Pure power billet oil filter, Katech tensioner, Improved Raving valley baffle, ported intake and throttle body, etc, etc...
On the attention to detail:
The entire block, both inside and out along with the cylinder heads have been completely grounded smooth. All the accessories front drive brackets and the motor mounts were completed sanded and powder coated in "Anthracite". The oil pan, valley tray and timing chain cover powder coated in texture black. The thermostat housing powder coated onxy, intake in a gun metal gray. The block, heads, alternator, ac compressor, power steering pump all sanded down of any casting and painted BMW "Frozen" gray It's a gun metal gray with flat clear). All the pulleys were given a brush finish. Ring Brother washer for the intake bolts and throttle body, Lokar dip stick, etc, etc ......
There is a lot more but you get the idea.
Here's a couple of pics:
After relocating the factory EVAC solenoid and negative battery cable that mounted to the front of the cylinder head, the 4 factory bolt holes on the were no longer needed, so they were welded in and the face re-milled.
The factory vapor tube was replace with XRP AN lines and fittings.
Old 10-27-2012, 02:45 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Originally Posted by Al Moreno View Post
..... It's a Gen"_"Camaro SS hes been working on.
Beautiful, just beautiful. That belongs in Chevy's museum. It's too darn pretty to put in a car. Now let's see some pics of what it's going in. You forgot to tell us what number gen Camaro your son has.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 10-27-2012, 03:44 AM
OVRKILL's Avatar
OVRKILL OVRKILL is offline
Nate is your son!!! Guess same last names should have been a give away He and I have had a few conversations over on Camaro5 in the past few months. He does beautiful work.....you should be proud. Lol, because of him, I now have a LOOOONGER winter list
'01SS - RHS 460
Fikse / MWC / Kinsler / Mast
Enough torque to buckle pavement!
"Went right past silly and all the way to stupid..." - Shawn Miller
Old 10-27-2012, 04:30 AM
Rick D's Avatar
Rick D Rick D is offline
Very nice Al, your son has a eye for details that's for sure He would fit right in at RS or Troys shop
Rick
Old 10-27-2012, 06:03 AM
MattG's Avatar
MattG MattG is offline
That's so pretty that it should be on a stand in my living room! I'm sure my wife would feel the same.
Great work!
'69 Camaro Coupe, Full Ridetech stage 3 suspension, moser wavetrac 12bolt, Forgelines, Ls3 Heads/Cam,T56 Magnum. Built by me and tuned by Ed!
'69 'Vert Camaro: DSE Sub-Frame, DSE Mini-Tub, DSE Four-Link w/9inch. LME LS7 427, T56. Tuned by Ed Hutchings, :SOLD!
Old 10-27-2012, 09:22 AM
NOPANTS68 NOPANTS68 is offline
Bitchin work. It's so smooth I thought it was a rendering at first. Amazing.
1929 Roadster Pickup
1961 Chevy Parkwood Wagon
1956 Chevy 210
Smithcraft Collision and Restoration
Newcastle , CA
Old 11-27-2012, 08:01 PM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
Really digging all the details Al..
We got the Firebird engine on assembly & detail right now.. got some cool new machined pcs for that one..
The intake might be replacing the intake for a carbon fiber unit.
Motor mounts with Prothane bushings.
Cris Gonzalez
Old 11-27-2012, 08:57 PM
Hey guys thanks for the props. I will have Nathan create an account when we get back from PRI next week (I will try to post pics from the show while there) and answer some of the questions asked. I think the Gen 5 front-drive is a great alternative and a economical option. The brackets are about $100 from the dealer. I also like the way it keeps everything down low as to not crowd the top of the engine.
Chris I can't wait to see what you come up with! Everything you do is top notch. You could probably tell there's a lot of your influence on these pics. Maybe Nathan can use some of your new stuff on his build.
The Following User Says Thank You to Al Moreno For This Useful Post:
JB400 (03-18-2019)
Old 11-28-2012, 08:48 AM
HEEP's Avatar
HEEP HEEP is offline
Has anyone found part numbers for these brackets? I'm wondering if factory setup like this is available.
By the way, as everyone has said, it doesnt belong under a hood. Awesome job.
HEEP
Old 11-28-2012, 01:06 PM
V8TV's Avatar
V8TV V8TV is offline
A very inspiring piece. Any more shots of the lower 1/2?
Kevin Oeste
V8 Speed and Resto Shop
V8TV
Muscle Car Of The Week
V8 Radio Podcast
All about us:
https://www.v8speedshop.com
