Old 06-12-2019, 06:29 AM
DWC's Avatar
DWC DWC is offline
Default Dash console
I've been working on a dash console to house some gauges, vents and HVAC controls. Still need to bodywork the seams, then paint it. It will attach over the OEM piece, then to the dash.
Daniel
The Following User Says Thank You to DWC For This Useful Post:
Roscoe03 (06-12-2019)
  #92
Old 06-16-2019, 06:28 PM
DWC's Avatar
DWC DWC is offline
Default Dash console continued
I got the dash console finished.
Daniel
The Following 5 Users Say Thank You to DWC For This Useful Post:
orangevert (02-05-2020), RdHuggr68 (07-09-2019), Roscoe03 (06-17-2019), waynieZ (06-20-2019), WILWAXU (06-24-2019)
  #93
Old 06-16-2019, 06:40 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
That turned out really nice! Well done!
Curtis
Old 06-17-2019, 08:50 AM
DWC's Avatar
DWC DWC is offline
Thanks Curtis.
Daniel
Old 06-18-2019, 07:42 PM
DWC's Avatar
DWC DWC is offline
Default Grill
Got the grill installed.
Daniel
Roscoe03 (06-24-2019)
  #96
Old 06-22-2019, 11:38 AM
CCS's Avatar
CCS CCS is offline
Daniel
Awesome!! Congrats, great job!!
1972 Chevy Nova
4 door sedan
350 sbc, TH350
Still stock rearend and suspension.
15" Ridler wheels
Old 06-23-2019, 02:33 AM
T_Raven's Avatar
T_Raven T_Raven is offline
Can I ask what color that is?
I've been looking for the right shade of blue for my 69 Firebird and I really like that
67, 68, 69 & 72 Firebirds, 79 TA, 89 GTA, 01 WS6, 68 Camaro, 68 Mustang, 54 GMC awd turbo, 67 GMC
Old 06-24-2019, 06:36 AM
DWC's Avatar
DWC DWC is offline
It's Grotto Blue. I haven't seen too many Grotto Blue cars in person, but mine seems a bit lighter than others. It could be because we used a white urethane sealer under the color versus a gray. Not totally sure though.
Daniel
Old 06-29-2019, 03:10 PM
DWC's Avatar
DWC DWC is offline
The dash console and gauge cluster is installed. I got the exhaust installed as well. I'm chasing some electrical gremlins- turn signals, brake lights, hazards aren't working. Think the tail light housings aren't grounded well due to the new paint.
Need to set the timing and adjust the carb because it's idling about 1500 rpms.
Daniel
The Following 2 Users Say Thank You to DWC For This Useful Post:
camcojb (06-29-2019), Roscoe03 (07-09-2019)
  #100
Old 07-09-2019, 08:24 AM
DWC's Avatar
DWC DWC is offline
I'd been fighting issues with the turn signals, hazards, brake lights and horn. I found the turn signal switch was old, brittle, and not working properly. Along with that the upper steering column bearing was worn out. It was the original, non-tilt, column, which I was planning to replace in the future. So, I went ahead and picked up a universal tilt column. I had to weld 4 nuts on shaft to be able to mount the stock column mounting bracket and adapt the rag joint to the bottom of the column shaft. But, overall it went pretty smooth and all the lights are now working properly.
I added a reverse switch to the Muncie, finished the wiring and secured the wires under dash, chased down some coolant leaks at the upper radiator hose, installed an MSD diode to remedy my engine run on, installed side mirrors, door locks and handles, etc.
I'm close to a test drive. Next up is finishing the interior. My *goal* is to have the car completed enough to make the next Cars and Coffee in town on 7/27. We'll see...
Daniel
