Old 09-04-2011, 09:27 PM
69-er 69-er is offline
Default Can't Lower Car w/ G-Bar System
I just finished mocking up the ChassisWorks 4-Bar system for a 69 Camaro. I have discovered that the VariShocks included with the kit, VAS 11122-515, will not allow me to lower the car to the height I desire. I was under the assumption that this kit would allow me to lower the car in a typical Pro-Touring stance. At the moment, I have about 1 1/2" of travel before I bottom out the coil-overs.
I noticed that there is another shock, VAS 11111-425, that has a shorter compressed length. I would lose almost an inch of compressed length allowing me to lower the car with less of a chance of bottoming out. Do you think this would work in my configuration? The car will be strictly street driven.
I also thought about lowering the lower shock mounts and maybe even raising the upper shock mounts to gain additional travel. What are your thoughts on this?
Thanks!
Old 09-04-2011, 10:03 PM
This seems to be happening on a regular basis with the new G Link. I'd lower or raise the shock mount. Shock travel is a good thing.
Old 11-08-2011, 02:42 PM
glr0212 glr0212 is offline
I was told the same thing.
This is supposedly the correct ride height for a g link. I was advised not to go lower.
Old 11-08-2011, 08:36 PM
Rybar's Avatar
Rybar Rybar is offline
I ran into a similar issue with mine, the shop doing the install installed a shorter spring but I don't have any part #'s to help you out.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 11-09-2011, 11:31 AM
6D9 Matt's Avatar
6D9 Matt 6D9 Matt is offline
Subscribing...
I am interested in installing a 4-link over the winter and Im kinda between the Prodigy Bar and the DSE Q-Link. Im not a HARDCORE autocross guy, etc the car is just for cruising around mostly, but may see the drag strip once a year. I was going to go with the Prodigy Bar, but kinda undecided now that Im hearing of it cracking the frame rails, as seen in Vegas69's build thread (I plan on dropping in a 600+ hp BBC next year). So that lead me to the G-Link, but I have heard these issues of not being able to go as low as some may like.
I think Rybar got the best of both worlds and put in a shorter spring. I remember following his build thread and seeing this. I would look into this option...
'69 Camaro
416ci / T56 / 9"
Turbo in the works...
Old 11-09-2011, 01:42 PM
Rybar's Avatar
Well not quite, the decreased shock travel is not something I would have wanted. If I were to do it over again there would be a DSE Quadralink in my car no questions asked. I also think the Speedtech Torque Arm gets the car to sit pretty low, look into that as well.
1969 CAMARO RS
