View Poll Results: 2 Dynos one winner Big Block Ford vs SB2
Sideoiler Makes the most peak hp 2 4.44%
SB2 Makes the most peak hp 18 40.00%
Sideoiler has the best average hp and tq (3500 to 7000) 12 26.67%
SB2 has the best average hp and tq (3500 to 7000) 13 28.89%
Voters: 45. You may not vote on this poll
Old 10-22-2012, 08:30 PM
FETorino's Avatar
FETorino FETorino is offline
Default Two Dyno days one winner
I know at least two people on here that are building something other than an LS. I'm calling the other guy out.
I'll have my Dyno results on the 9th or 10th of Nov. Who thinks that little SB2 Flash is building will beat my 1960s tech motor?
What ya got Dave? Will that motor of yours run this year or not
45 year old cast iron Tunnelport heads. Intake flow #s on a conservative flow bench.
Lift before after
.100 101 98
.200 173 168
.300 215 228
.400 243 262
.500 270 295
.600 294 322
.700 311 343
One of two Original Ford intakes a 2x4 with a pair of 750s or a single 1050 dominator (I'm running both on the dyno)
Pond Al sideoiler block
Crower forged crank 4.375 stroke with my bore it puts me at 496ci
Crower 6.7 rods
Custom CP pistons to put me @ 11 to 1
Crower bushed style solid roller lifters and a BP cam targeting peak power around 6200rpm.
T&D rocker set
Smith Bros pushrods
Dailey engineering 4 stage dry sump
Locked out MSD dist with MSD digital II CDI with programable ignition curve.
Electric water pump
Rob in SoCal
Old 10-22-2012, 08:45 PM
Flash68's Avatar
Flash68 Flash68 is offline
Wait... what? How many cubes you got? You know if I was smart I woulda said we compare hp/tq per cubic inch!
You go first....good...so I can turn up the wick when it's my turn.
I'd have to guess (hope) I'll be on the dyno by end of November.
Dart Little M block
4.170 bore x 4.00 stroke = 437 cubes
10.8 to 1 compression
Joe Gibbs SB2.2 heads
Ported GM intake
Single 4150 Holley style carb (will dyno 2-3 carbs)
6 stage dry sump system
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 10-22-2012, 08:54 PM
FETorino's Avatar
I can see you now..... Hey Mike what if we put a bigger cam in this thing will we be able to beat the Ford? The other Chevy guys on the forum will never let me forget this.
Rob in SoCal
Old 10-22-2012, 09:24 PM
What are the power aspirations for you guys that like to do things the hard and expensive way?
Old 10-22-2012, 09:27 PM
FETorino's Avatar
I didn't set the bar very high. Just about 10% higher than an old ZL1.
Rob in SoCal
Old 10-22-2012, 09:41 PM
Flash68's Avatar
Hard and expensive. Check.
A 23 degree SBC can hit those numbers.
2014 4 tap Keezer
Old 10-24-2012, 10:43 PM
FETorino's Avatar
Thinking back it seems we answered this question twice.
Rob in SoCal
Old 05-24-2013, 09:50 PM
FETorino's Avatar
I'd have to guess (hope) I'll be on the dyno by November.
Dart Little M block
Ported GM intake
I guess he meant Nov 2013
Rob in SoCal
Old 05-24-2013, 09:56 PM
fleet's Avatar
fleet fleet is offline
Sounds like the whole contest is going up in smoke...
Old 05-24-2013, 10:01 PM
FETorino's Avatar
That looks like the BBQ spot Brian took us to in TX.
Rob in SoCal
