Old 01-11-2022, 06:42 PM
SSLance's Avatar
SSLance SSLance is offline
Originally Posted by ScotI View Post
Is that w/the link in the middle or upper hole? I know you mentioned making changes:
Just curious if you switched everything back to the initial points & then all that was required was the slight adjustment on the upper link?
I had to push the housing forward to get bolt in upper hole so that change probably helped a little, then shortening the link finished it off.
Eventually I'll remeasure it all to see where IC and AS ended up to see of it needs further fine tuning.
Lance
Old 01-15-2022, 05:30 AM
SSLance's Avatar
Who else is as excited as I am to see what this thing can do tomorrow?
Course has a ton of transitions in it along with a couple sweepers, exactly the test bed to see how much the 3 link improved the car's rear grip.
https://forum.azsolo.com/index.php?/...nt-1-jan-16th/
Car is washed, full of fuel, have a new case for the GoPro and the weather forecast shows high 60s-low 70s and partly clouds tomorrow.
Let's do this!!
Lance
Old 01-15-2022, 07:03 AM
Tinker's Avatar
Tinker Tinker is offline
Probably nobody.......not saying we're not excited, but you are like a kid on Christmas eve!
Good luck Lance.
Chris
The Following User Says Thank You to Tinker For This Useful Post:
SSLance (01-15-2022)
  #1144
Old 01-15-2022, 07:48 AM
rixtrix1's Avatar
rixtrix1 rixtrix1 is offline
Good luck Lance.
Haha, maybe a few "Oh,sh*t, how fast will he be now?!" Good luck!
Ric
2002 S-10, Daily Driver and autoX
1966 Chevelle MALIBU ( mine since 1971) Drag car converting to a track car!
The Following User Says Thank You to rixtrix1 For This Useful Post:
  #1145
Old 01-15-2022, 12:33 PM
I'd be more excited if you invested the money in a mullet vs. a 3 link, but hey, good luck out there tomorrow.
The Following User Says Thank You to Vegas69 For This Useful Post:
  #1146
Old 01-15-2022, 01:52 PM
SSLance's Avatar
Lol at you all.
Yes, I'm pretty stoked. This was a LONG time coming and the initial reactions show a LOT of promise...
Lance
The Following User Says Thank You to SSLance For This Useful Post:
rixtrix1 (01-15-2022)
  #1147
Old 01-15-2022, 02:42 PM
ScotI ScotI is offline
Looking forward to the update. I'm hoping it's a positive day for you!
The Following User Says Thank You to ScotI For This Useful Post:
  #1148
Old 01-16-2022, 05:23 PM
SSLance's Avatar
So the day didn't go exactly as planned...
First two runs were great, completely different car yet still very responsive and easy to drive. I was about a second or so ahead of Mike in his Chevelle on both runs, then sitting in line to start 3rd run in neutral I pushed the clutch in to shift to 1st and the pedal went to the floor. Pretty sure I have a clutch fork issue but Barney was out.
Mike graciously let me slip into his seat for my last 3 runs. It was awesome for him to do that and to feel my setup on course then to go directly to his setup (which is very similar to mine) and feel the difference. Final verdict from today, 3 link is the answer!
This video is my second run, only adjustment from first run was 3 clicks softer on rear rebound.
I took a passenger and felt a slight RR tire rub on one long sweeper so I added some tape to verify where, added some compression to rear shocks and had tools out to raise PHB after 3rd run...but it wasn't to be.
Here are the final results for the day.
http://solo-timing-api.herokuapp.com...ass-Open_CAM-T
It'll be a day or two before I can diagnose the clutch, but pretty sure the trans has to come out first too see what's up...so yeah...
Lance
syborg tt (01-17-2022)
  #1149
Old 01-16-2022, 06:41 PM
Well.... I guess that's a 'good news/bad news' thing.
Glad it initially went well but sux to hear about a clutch issue ending further evaluation.
SSLance (01-19-2022)
  #1150
Old 01-18-2022, 05:46 PM
Bummer about the clutch. That's great that it's performing better with the rear changes though. Good luck, Lance.
