Old 04-22-2015, 08:34 AM
fleet's Avatar
fleet fleet is online now
WTF - Why would you ditch the shroud???
Originally Posted by Panteracer View Post
I am talking about deleting the stock shroud which
actually holds the radiator in on a 70s bird
The new rad has its alum shroud that I am keeping
but will not fit inside the old plastic assembly
Bob
I wanna go on record as being 'pro' shroud.
Seriously Bob, enjoying seeing the ole beast get some nice tweeks.
Old 04-22-2015, 10:27 AM
ONEBAD78TA's Avatar
ONEBAD78TA ONEBAD78TA is offline
A Pontiac without a shroud = a very hot Pontiac.
Don't hate me because I just passed you like you were standing still OH YEA THAT JUST HAPPENED
Old 04-22-2015, 06:40 PM
Bob I simply took a piece of 090 aluminum and bent it 90* to hold my radiator in place. I bolted it to the core support and used the stock upper radiator pads. It looks like a typical radiator cover. I even used it to hold the top of my electrical fans in place since I'm using the 4th gen fans. No issues with it moving around. I haven't pushed my car as hard as you have though. I don't see it becoming a problem though. Good luck getting the radiator in. Hope it works well for you.
Here's a picture
Old 04-22-2015, 08:45 PM
Panteracer's Avatar
Panteracer Panteracer is offline
Default Dreamin Ta's
I was thinking that might be how I do it
I like the fact you covered the old metal completey
I was thinking about drilling the hell out of the existing
metal to lighten things up so I need something to
cover it so the air goes thru the radiator
Radiator project is on the back burner until i finish
getting the Pantera ready for Texas
Bob
Old 04-23-2015, 06:52 PM
The picture is misleading. I only cleaned up the core support and repainted it. The radiator cover replaced the shroud only. It begins right on top of the support like the shroud did.
Here we go. Here's and outside picture from the front that shows them as being two separate pieces
Eventually, I do plan to close out the front area to prevent air from going over the core support. I also intend to close up the nose area from underneath and make the front end more like a modern car that only brings air in through the bottom. All in time. For the present, I have no cooling issues and I really need to make an overflow tank. I think I'll work on that once I finish the exhaust.
Good luck getting the Pantera ready
Old 04-23-2015, 07:56 PM
Panteracer's Avatar
I see it now. I think I may close it up to the nose
Bottom is covered by the spoiler that goes under the
radiator Not sure if that is good or bad as no air
passes up from below?? Was thinking
of angling the sides in front of the radiator that will have
some intakes that i can duct to the brakes but direct air
thru the radiator more effectively
Bob
Old 04-24-2015, 08:38 AM
Firebirdsteve's Avatar
Firebirdsteve Firebirdsteve is offline
I did this...
Just need to paint the hardware BLACK!!!
1981 Pontiac Firebird
Build by Speedtech Performance
http://www.speedtechperformance.com/...rod/prd287.htm
Old 04-24-2015, 10:33 AM
looks good, Steve. Can you get a side shot?
Old 04-24-2015, 12:34 PM
Old 04-24-2015, 12:43 PM
carbuff's Avatar
carbuff carbuff is offline
I'm really happy with the one that Eric made for TOW:
