Old 12-01-2014, 10:27 AM
Nativefx Nativefx is offline
Originally Posted by Stovebolter View Post
I mounted my tires on the wheels, placed them in the wheel wells, dropped the car to ride height and measured between the wheels. That's the same suggestion others on here gave me. And it worked out for me. It will tell you what you need for distance wheel mount to wheel mount. BTW....you should have a little extra room with the 325s and a mini tub compared to my set up.
Yeah, I understood the measuring for WMS to WMS. i was just wondering how much space you left between the tire sidewall and the outer fender? Did you leave more space between the inner fender and tire sidewall, or did you just center the tire and leave equal distance on each side? I'm hoping with the 325 I do have a little more room as I really hope i don't have any rubbing issues.
Old 12-01-2014, 12:31 PM
Payton King's Avatar
As long as your TA is and I assume it is 6 to 8 inches at the front at ride height, your wheel hop is probably coming from shock dampening and spring rate if I were to guess.
Old 12-01-2014, 12:32 PM
Where is your watts piviot in relationship to axle centerline?
Old 12-02-2014, 08:27 AM
Stovebolter's Avatar
Stovebolter Stovebolter is offline
I centered the tire and ended up with roughly a 1/4" of clearance on both sides of the tires......inside and outside.
468 BBC, TH400, Moser 9" floater, True Forged Competitions 18x9.5 18x12, Kore 3 C6 ZO6 calipers 14" & 13" rotors, Ride Tech True Turn, Ride Tech Air TQ's, Torque Arm with Watts link, Moser CT Full Floater 9" with locker.
Old 12-02-2014, 08:36 AM
I'll have to check it again but if memory serves me correct, it is just above axle center line. I have air springs.....I could move the mount points up or down but I'd sacrafice travel up or down. I could slow up my rebound and leave my compression where it is. That makes sense. That should counteract the hop. I'll try it.
Thanks again Payton.
Old 12-02-2014, 09:37 AM
With it above center line you have raised the roll center and loosened the rear. The lower you go the more bite you will have in the rear. Try an inch or 2 below axle centerline. Is your watts fixed or adjustable? I assume your rear trailing arms are level at ride height
Old 12-02-2014, 02:56 PM
Yes, trailing arms are adjustable at rear mount....but level at ride height at this time. I may be wrong on the front mounting point. I remember you gave me roughly what yours was set at, and I added 2"s of adjustment in 1" increments both ways and took in consideration the axle centerline. I bet it's below. That would make better sense. I'll check it when I can get to the shop.
And Watts Link has a lot of adjustment.
Thanks.
Old 12-03-2014, 06:11 AM
I was not speaking about the front mount. I would guess it is 6 to 8 inches from the ground at ride height. I am speaking of the watts pivot in relation to your axle centerline at ride height. The lower the pivot the more bite you will have up to a point. I would start it at or 1 inch below axle centerline and start messing with the shocks.
Increasing the rebound valving like you stated earlier would help as well.
Old 12-04-2014, 08:02 AM
Lol. I over complicate things often. Yes...the front mount is about 5.5" from ground. At this time the Watts link pivot point is centered with relation to axle center line. I'll try raising it an inch and see what I get with a little more dampening on rebound. Man these TQ shocks are cool. Reminds me of my days competing in the Hare Scrambles via woods MX. Same adjustments available.
Old 12-04-2014, 08:05 AM
Tell me it isn't so...are we going to lose Heartland to the city of Topeka for not paying their bills? I hope they keep it open. If not that puts my closest track with Elkhart. Frustrated.
