Old 12-14-2013, 04:03 PM
kwhizz's Avatar
kwhizz kwhizz is offline
Got all the sheet metal installed and finish bolted in......Got the front Bumper back on and I also got the ECM and Trans Modules installed......Forward Lamp harness is next along the getting the Intercooler pump wired.......Now......I just need to find my Horns......they are here somewhere.......Dammmm!!!
Old 12-14-2013, 04:09 PM
Don't forget that lower radiator hose!
Looks good Ken!
This thing is moving along pretty fast! Good to see!
Old 12-17-2013, 04:49 PM
kwhizz's Avatar
First off......I would like to thank the person who brought my horns back and put them in the garage on the table in plain view........Thanks........
Now.....I got that mess of wires all cleared up in the front of the car.......I hooked up a temporary power feed and checked out the lights.........They actually worked......LOL........I bought an American Autowire Classic update wiring kit and they have anticipated any combination of options and or Gauge/Engine options......I was intimidated by the amount of wires and circuits in the beginning.....but......after looking at what I really needed to hook up....I started removing wires from the bulkhead .......Example.......with the Speartech LS harness, most everything is taken care of in that harness.....blending it into the system is as simple as a fuel pump lead a couple of grounds and keyed ignition power and Battery........That's about it......The Auto engine harness had a bunch of wires in it.....I ended up using 4 wires.....one for the Solenoid and three for the windshield wiper/ Pump assy.......The forward lamp harness was about as simple....about the only major thing I have left to do is tackle the inside.......That's next.....Hopefully the wheels and tires will show up soon also.......
Old 12-17-2013, 05:01 PM
That's so damn funny about those horns! My guess is they were mating in a box somewhere and when finished with their business -- they just went back to being where the last 'idiot' left them… I personally hate that when it happens to me. Did I ever tell ya bout looking for a screwdriver all day --- and some azzwipe had put it in my back pocket?
When people have me come "help" them figure out how to start their wiring projects -- I always give them this simple advice (it comes from having to wire fireworks shows with 1000's of pairs of wires). Just start with ONE wire -- forget about all the others there -- pick it up -- run it (leave it a bit long and leave it loose)… label it or terminate it…. go back and pick up another one… do this repeatedly until done. LOL
I hate wiring (well not really) - but it really isn't ever as hard as a "newb" thinks it is. I know you're not a newb at this.. just sayin'.
Old 12-17-2013, 05:19 PM
kwhizz's Avatar
Spoken from a man with "Spear-e-ence".............LOL
Old 12-20-2013, 01:14 PM
kwhizz's Avatar
I got the inlet air tube assy fabricated and fitted to the car .....Just need to weld it up and make the mounting plate for the mass airflow sensor.........Now it time to get started on the inside wiring...........
Ken
Old 12-20-2013, 01:59 PM
Jon69RagTop Jon69RagTop is offline
Default Okay, little too much napping going on.
We wait for days for the next update and that's all we get.
Keep plugging away, I'd like to see this on Power Tour 2014, not 2015.
Have a Merry Christmas.
Old 12-24-2013, 01:50 PM
kwhizz's Avatar
Been working on the car every day........I am just about finished with the wiring in the Engine compartment......got the fan relay's installed along with the Battery cables, Dakota digital lines for the relays......fuel system wires all installed for the Vaporworx system.......The pressure Module was just finished up and is in transit....I also have all the Vintage Air wires hooked up........I also have the trans cooler lines fit and installed..........This Voltmeter guy stuff never ends.......But.....I did spin the engine over today.......Getting close.......No pictures of progress because everything looks the same......LOL.....Getting close to tackling that pile of wire on the inside of the car......
Merry Christmas to All!!
Old 12-27-2013, 05:12 AM
kwhizz's Avatar
I got the inlet tube welded up and I just need to make and weld in the Mass Air Flow mount fitting..........I also got my Vaporworx fuel pump controller......gonna make a bracket today to get it mounted and get it finish wired up today.......All the wires seem to terminate around the Battery and the one I'm using is both a top post and side post.....makes it a lot easier to tap into for battery power.....the mass of wires look like a mess but when the Battery is in everything falls into place.......Getting Closer....
Old 12-27-2013, 05:56 AM
Wow you've been a mighty busy boy Ken! Looking good! I like the brushed look on the inlet tube.
Did I ever tell you I hate wiring? LOL I've spent DAYS making it all just go away... UGH! The stuff just is... Well I can't even think of any comparison right now that wouldn't get me tossed off here.
