Old 03-17-2016, 08:22 PM
Che70velle's Avatar
Exceptional work Ken!
Thanks Dad!!
Old 03-18-2016, 04:32 AM
kwhizz's Avatar
kwhizz kwhizz is offline
Having second thoughts about using a rubber feed line submersed in Gasoline in the tank.......Does anyone know what type of material the Soda straw tubes and GM pump bodies are made from and what type of adhesive/sealant is used by GM in the assembly process ????????
Ken
Old 03-18-2016, 05:43 AM
grendel grendel is offline
Very nice build.
I wouldn't do rubber either, maybe a TFE hose?
Sorry, I don't know what they're made of. Perhaps call Hector at Rick's Tanks?
He helped me out with a bunch of tanks for odd ball vehicles.
My garage builds, with some hack and professional love thrown in:
68 GMC C1500
Haulin more than the mail
73 Camaro
Better grow a mullet
70 K5 - 4wd turned 2wd
Project might as well...
Known as John or "JJ"
Old 03-18-2016, 07:02 PM
turnhard turnhard is offline
Ask mark of bent custom and performance he is a vendor here. He specializes in all types of line . Kevin
Old 03-25-2016, 12:45 PM
kwhizz's Avatar
Been busy at the shop so not a lot of time for Car parts......I finally got the fuel pump situation put to bed........I ordered a set-up from Ricks that has a dual filtered in tank pick ups for supplying the fuel pump......there are a couple of brackets that the pick-ups snap into that needed to be tack welded in the Tank to hold them in position......Got that finished today........Now I can finish welding the Pump plate into the tank.........Getting real close !!!!!!!
Old 03-25-2016, 07:07 PM
It's looking good Ken.
Old 04-06-2016, 05:02 PM
kwhizz's Avatar
Got home from Vacation and I was hoping the Elves would have the car back together.....No Luck......Gas Tank is not finished yet either........But !!!......Got a box in UPS with new shocks in it........Can't do anything till the Tank gets finished.......Darn !!!!
Old 04-15-2016, 04:41 AM
kwhizz's Avatar
Look what is finally finished..........I'll get it installed........finish up the fuel line.......install the Vaporworx fuel pressure control system........then off to the Exhaust shop........
Old 04-16-2016, 03:24 PM
kwhizz's Avatar
Got everything finished except for the Exhaust system........all the wiring is completed......the last wires were for the Vaporworx fuel pressure controller......got it buttoned up and turned the key on......The pump ran for a couple seconds and shut off......with out starting that's exactly what it's supposed to do..........Now I have to put some gas in the tank to start it up......then get it to the exhaust shop...........Next project coming up shortly is to take the 454 out of Gary's 65 Biscayne and swap in a LS3.........Stay Tuned........
Old 04-16-2016, 05:21 PM
zz430droptop67rs's Avatar
zz430droptop67rs zz430droptop67rs is offline
Thumbs up
Love that car!
