Old 01-25-2019, 08:22 PM
Brianstanford Brianstanford is offline
https://youtu.be/X9PKx7toD6E
Running vid
Instagram @brianstanford
Old 01-25-2019, 08:24 PM
Greyson heard the camaro start and had to come see what was going on! I love it!
Old 01-26-2019, 05:58 AM
Awesome man. Huge milestone there.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
The Following User Says Thank You to will69camaro For This Useful Post:
Brianstanford (01-26-2019)
  #124
Old 01-26-2019, 03:59 PM
I'm pretty excited about it!!!
Old 02-07-2019, 09:06 PM
Old 02-13-2019, 06:12 AM
Starting to work on brake lines. I have a roll of 3/16 nicopp line and all the fittings and a Eastwood flaring tool but suck at bending.... would it be better to order pre fit lines?
I know the pre fit lines won't line up with my master cylinder (DSE) but dont mind bending some of the lines. Main one's I'm concerned with is the front one that goes under the motor on the subframe & the one that runs to the rear
Any suggestions? Thanks
Old 02-13-2019, 05:19 PM
Tinker's Avatar
Tinker Tinker is offline
I used the prebent stainless lines from inline tube on my Firebird. I have the Wilwood m/c and all the lines worked well with it. I was very happy with the fit and appearance. I added the hardware and clips for a very nice install.
Chris
The Following User Says Thank You to Tinker For This Useful Post:
Brianstanford (02-16-2019)
  #128
Old 02-15-2019, 12:48 PM
ScotI ScotI is offline
I've done the Pre-Bent route to save time & it worked fine. I also used Inline Tube.
For me, I just needed to tweak certain areas vs. needing to make every single bend. Work smarter.... not harder.
The Following 2 Users Say Thank You to ScotI For This Useful Post:
Brianstanford (02-16-2019), Spiffav8 (02-16-2019)
  #129
Old 02-16-2019, 03:14 PM
Thanks guys! Sounds like pre-bent is the way to go
Old 04-04-2019, 02:47 PM
Dad and I ran NiCop brake lines front to rear with a wilwood prop valve & Kore3 flex lines. Used an Eastwood flaring tool to make the double flares
